Part Number for GTI Alternator
As title, trying to get prices for a new alternator to replace my knackered one most places are asking for the part number. Part number asap if anyone has it??
Also does the GTI use a 70 amp or 90 amp one?
Daryl
The GTI uses both. I think the aircon version had the 90amp and non aircon 70amp
Off VAGCAT
alternator and single parts
alternator / 70A
1047903015Qalternator
BOSCH / (1)047903015QXalternator
BOSCH / (1)047903018 Xalternator
VALEO / (1)037903018BXalternator
VALEO / (1)037903018CXalternator
VALEO / (1)038903018KXalternator
BOSCH / (1)038903018MXalternator
BOSCH / (1)06B903018RXalternator
BOSCH / (1)030903023EXalternator
VALEO / (1)037903023QX
alternator / alternator / VALEO 90A
(1)038903018alternator with terminal -w-
BOSCH / (1)038903018 Xalternator with terminal -w-
BOSCH / (1)038903018Aalternator
BOSCH / (1)038903018AXalternator
BOSCH / (1)047903018Aalternator
VALEO / (1)047903018AXalternator
VALEO / (1)038903018Calternator
BOSCH / (1)038903018CXalternator
BOSCH / (1)06B903018KXalternator
VALEO / (1)038903018LXalternator
BOSCH / (1)06B903018MXalternator
VALEO / (1)037903023GXalternator
VALEO / (1)036903024alternator
BOSCH / (1)028903025Palternator
BOSCH / (1)028903025PX
alternator / alternator / BOSCH 110A
(1)036903018alternator / also use:
BOSCH 038 903 119 B / (1)036903018 X
alternator / alternator / BOSCH 120A
(1)038903018BXalternator
BOSCH / (1)045903023Aalternator
BOSCH / (1)045903023AX
Cheers Mike, i am struggling getting the thing off the car, seems that the last bolt catches on the chassis leg. Have you done a change before and do you need to drop the engine? If so what's the best way to so this? Undo engine mounts while jacking the engine for support?
Edited by Dazz
Yey alternator out the car! Tomorrow shall be spent finding some decent prices! What a faff though took about 3 hours, would say a mere hour if I was to do it again, now I know what to do! :)
Yeah was pretty much as you described,supported the sump and dropped the engine about 20mm or so and voila it was out. Was only a faff as i didn't know what to do really! GSF are the cheapest for a Bosch unit @ £108.50 + Surcharge so i think i will go with them.
Yours is a Bosch then?
The Lucas items have a removable voltage regualtor where the Bosch does not. Its cheaper in the long run if it packs up again, as Lucas provide replacement regulators.
I was happy to find out my GTI had the Lucas version
Edited by Mike_M
Ah right, the Lucas unit is £11 dearer than the Bosch, how much ate the regulators if you know?
Just I can get a Bosch unit this afternoon otherwise I have to wait until after the weekend for a Lucas one.
Well that settles it then Lucas it is. I take it the Bosch units have solid state regulators?
Ok cheers for the help Mike hopefully everything will be sorted at the weekend!! :D
Edited by Dazz
Alternator is all in now, car runs fine, but the belt is rather squeaky? NEver did this with the old alternator and the belt seems tight enough. Any ideas?
Ah right that will most likely be my problem then. The belt was off for about a week without any tension so maybe its just gave up on life. I shall sort this out soon! Thanks Mike
  • 9 years later...
