dodgercannon Posted February 5, 2010 Report Share Posted February 5, 2010 Hi all,had a lack of boost for the past couple of days... Which has lead me to belive it's the n75 valve.Just wondering how much these are?Cheers guys Quote Link to comment Share on other sites More sharing options...
dodgercannon Posted February 5, 2010 Author Report Share Posted February 5, 2010 Anyone? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 5, 2010 Report Share Posted February 5, 2010 A what?VW might know. Quote Link to comment Share on other sites More sharing options...
dodgercannon Posted February 6, 2010 Author Report Share Posted February 6, 2010 its a boost controller, has vacume pipes connected to it. VW will charge through the nose. Quote Link to comment Share on other sites More sharing options...
north wales loop Posted February 7, 2010 Report Share Posted February 7, 2010 its a boost controller, has vacume pipes connected to it. VW will charge through the nose.heY! had the same lack of boost problem for the last week,under further investigation i found that the pipe thats connected to the intercooler had come off. maby check that first before taking it to a garrage? save you some cash. Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 7, 2010 Report Share Posted February 7, 2010 Get it plugged into vagcom and check the opperation of it before you go spunking money on a new one!Also check over your boost hoses, in particular the one that comes directly out from the turbo. Mine used to chew through these for fun until 1 litre Screamer made me a carbon protector sleeve! Quote Link to comment Share on other sites More sharing options...
dodgercannon Posted February 7, 2010 Author Report Share Posted February 7, 2010 See I dont think its any of the pipes because its boosting normally then when Im doing 60+mph the boost just dissapears and doesnt come back untill I turn the car off and back on again, its then restored untill I do 60. Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 7, 2010 Report Share Posted February 7, 2010 So it's going into limp mode then? Could be a shagged turbo charger.Like I say, VAGCOM it... Car's are built with a Diagnostics port for one reason and one reason only! So that when something goes wrong you have a starting point. Quote Link to comment Share on other sites More sharing options...
Gazza Posted February 17, 2010 Report Share Posted February 17, 2010 When it was crashed it was run with no air box for a couple of days, so either get it on vagcom or take to vw this way you will know for defo also check inter cooler pipes down on the drivers side as these were fubarred and possible wasnt replacedso how much did you pay for it then? Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 17, 2010 Report Share Posted February 17, 2010 oh dear... If the engine was run without an airbox for a couple of days, then the chances are the turbo would have sucked something in...I've seen it before now where even a drop of oil on the impeller blades of the turbo charger whilst spinning have bent them out of shape. If a stone or some grit got in, it could have totalled the turbo!!!Take off the turbo intake pipe and inspect the impeller wheel. You may find it's that causing the issue. Quote Link to comment Share on other sites More sharing options...
Gazza Posted February 18, 2010 Report Share Posted February 18, 2010 Whoooooop seeeeeeeeeeI still have loads of receipts and the service book for this motor, which could be sold for the right price LOL Quote Link to comment Share on other sites More sharing options...
