electricpanda Posted February 2, 2010 Report Share Posted February 2, 2010 Just after abit of information,How difficult is it to get one working on the Lupo?Is it a case of sourcing a Mk5 boot, a lupo boot, chopping out what I need from the Mk5 Boot, welding and grinding and smoothing it onto a Lupo boot?It sounds very time consuming, do the people who have them use a popper or have it wired up to the central locking?Any help is appretiated!Thanks! Quote Link to comment Share on other sites More sharing options...
TomStevo Posted February 2, 2010 Report Share Posted February 2, 2010 well u wud have it to the central locking just like standard as you still have a handel so ne need for a popper, and yes thats pretty much it, i know you can buy the mk5 handle but obv you dont any metal work from around it, find a mk5 tailgate, cut it out leaving a decent amount of metal around the handle, cut a near identical hole in a lupo boot lid and weld it in, you do have to cut some of the lupo boot inners to get the handle in, i shall be doing this soonish, fairly easy if you know how to weld Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 2, 2010 Report Share Posted February 2, 2010 (edited) well u wud have it to the central locking just like standard as you still have a handel so ne need for a popper, and yes thats pretty much it, i know you can buy the mk5 handle but obv you dont any metal work from around it, find a mk5 tailgate, cut it out leaving a decent amount of metal around the handle, cut a near identical hole in a lupo boot lid and weld it in, you do have to cut some of the lupo boot inners to get the handle in, i shall be doing this soonish, fairly easy if you know how to weldErr, No.The Golf handle is electric, so you do need a popper, wired into the central locking, via a relay or two. Edited February 2, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 2, 2010 Report Share Posted February 2, 2010 well u wud have it to the central locking just like standard as you still have a handel so ne need for a popper, and yes thats pretty much it, i know you can buy the mk5 handle but obv you dont any metal work from around it, find a mk5 tailgate, cut it out leaving a decent amount of metal around the handle, cut a near identical hole in a lupo boot lid and weld it in, you do have to cut some of the lupo boot inners to get the handle in, i shall be doing this soonish, fairly easy if you know how to weldHAHA, you think its that easy? Let me give you a little insite in to the work that went in to mine, im not trying to sound arrogant or argue here before i start!You need a donor boot, becasue the mk5 handle itself does not sit flush against the golf boot skin, there is a big mounting assembly and framework in it that needs to be used to get it to sit fush. That is spot welded to the skin and has to be split and then welded to the lupo boot once you have done your hole for the handle. This needs to be spot on, as there is no room for adjustment and it will look poop if you get it in the wrong place or offset a little.Once you have achieved the metalwork, you can then seam weld arond the edge to stop it leaking then flat it back, skim it and paint it. Astetically its sorted after that, Its very labout intensive if you want a good job, dont expect much change from £400!Then theres the wiring, Firstly there is no power in the boot that can be used for the popper, The wire needs to be about 17 amp gauge. That needs to be fed in to the boot.... good luck with that as its quite a pain! Inline fused and connected to the battery. You then need to mount the popper, again it needs custom brackets making and cutting of the framework to run smoothly.Now, you have power and your popper.. How do you get it to work?The mk5 handle is electronic, has a very small microswitch which cannot handle the current you will draw from the boot popper. This needs to be fed through a relay to power the popper main supply. Then if that works, the boot will be unlocked all the time and you wont be able to lock it. So you then need to control the power feed to the microswitch by taking out the central locking module and putting a relay in to change state when a central locking pulse is detected.Easy huh? Quote Link to comment Share on other sites More sharing options...
electricpanda Posted February 2, 2010 Author Report Share Posted February 2, 2010 Cheers for the info John! Doesn't sound as DIY as I was hoping.. Quote Link to comment Share on other sites More sharing options...
Mr ColinG Posted February 3, 2010 Report Share Posted February 3, 2010 HAHA, you think its that easy? Let me give you a little insite in to the work that went in to mine, im not trying to sound arrogant or argue here before i start!You need a donor boot, becasue the mk5 handle itself does not sit flush against the golf boot skin, there is a big mounting assembly and framework in it that needs to be used to get it to sit fush. That is spot welded to the skin and has to be split and then welded to the lupo boot once you have done your hole for the handle. This needs to be spot on, as there is no room for adjustment and it will look poop if you get it in the wrong place or offset a little.Once you have achieved the metalwork, you can then seam weld arond the edge to stop it leaking then flat it back, skim it and paint it. Astetically its sorted after that, Its very labout intensive if you want a good job, dont expect much change from £400!Then theres the wiring, Firstly there is no power in the boot that can be used for the popper, The wire needs to be about 17 amp gauge. That needs to be fed in to the boot.... good luck with that as its quite a pain! Inline fused and connected to the battery. You then need to mount the popper, again it needs custom brackets making and cutting of the framework to run smoothly.Now, you have power and your popper.. How do you get it to work?The mk5 handle is electronic, has a very small microswitch which cannot handle the current you will draw from the boot popper. This needs to be fed through a relay to power the popper main supply. Then if that works, the boot will be unlocked all the time and you wont be able to lock it. So you then need to control the power feed to the microswitch by taking out the central locking module and putting a relay in to change state when a central locking pulse is detected.Easy huh?Piece of P... Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 3, 2010 Report Share Posted February 3, 2010 Piece of P... When you get someone to do it for you then.... yes it is Quote Link to comment Share on other sites More sharing options...
Mr ColinG Posted February 3, 2010 Report Share Posted February 3, 2010 When you get someone to do it for you then.... yes it is Is that what you did? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 3, 2010 Report Share Posted February 3, 2010 Quote Link to comment Share on other sites More sharing options...
12yan Posted February 3, 2010 Report Share Posted February 3, 2010 Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted February 3, 2010 Report Share Posted February 3, 2010 After reading that im totally happy with the regular boot handle ha ha Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 3, 2010 Report Share Posted February 3, 2010 (edited) It might be easier to fit a Lupo badge to the rear of a mk5 Golf. Or maybe adapt a Golf tailgate to fit a Lupo?I got the Golf tailgate, popper kit and relays , but gave up as i couldn't decide what sort of tailgate I wanted, or if I should hack apart my own. Edited February 3, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
TomStevo Posted February 4, 2010 Report Share Posted February 4, 2010 wow, never knew the handle was electric! loland the mk5 golf one would not sit flush however wouldnt the new polo one sit flush? that has a fairly flat tailate, would be alot easier than the mk5 golf onedoes the handle have a key hole under it like the mk2 arosa boot handle? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 4, 2010 Report Share Posted February 4, 2010 No, because it is electric you don't need any sort of key. Just switch the power off to it and it's locked.John Quote Link to comment Share on other sites More sharing options...
electricpanda Posted February 4, 2010 Author Report Share Posted February 4, 2010 Worth the money to have it done, would have been amazing if they came like that from the factory. The standard handle looks out of place with the rest of the car. Looks like a job for summer. Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 4, 2010 Report Share Posted February 4, 2010 I've been told a bodyshop could do this mod for no more than Twelve Pounds... Is this correct? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 4, 2010 Report Share Posted February 4, 2010 (edited) I've been told a bodyshop could do this mod for no more than Twelve Pounds... Is this correct? Edited February 4, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 4, 2010 Report Share Posted February 4, 2010 tee hee. Quote Link to comment Share on other sites More sharing options...
henlupo Posted February 5, 2010 Report Share Posted February 5, 2010 (edited) has any one got a custom circuit diagram ,which popper to use ,or any pics apart from bluloop as it only shows metal work. cheers Edited February 5, 2010 by henlupo Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted February 5, 2010 Report Share Posted February 5, 2010 Why doesnt someone use the boot handle that came off the early new-shape beetles? The one that swiveled round? I think that would be pretty cool! Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 5, 2010 Report Share Posted February 5, 2010 has any one got a custom circuit diagram ,which popper to use ,or any pics apart from bluloop as it only shows metal work. cheers Nope, Its a work it out yourself job sadly.John Quote Link to comment Share on other sites More sharing options...
henlupo Posted February 5, 2010 Report Share Posted February 5, 2010 ok, any pointer on the solenoid type and placement..... Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 5, 2010 Report Share Posted February 5, 2010 10lb solenoid i think i used.Placement, well you need to think of a straight line from the release latch, and then find some framework to bolt the retainer to. Quote Link to comment Share on other sites More sharing options...
henlupo Posted February 5, 2010 Report Share Posted February 5, 2010 found this !!!!!! http://forums.motivemag.com/zerothread?id=3805203 Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted April 8, 2010 Report Share Posted April 8, 2010 Thinking about this mod now after seeing it done on MK4's and looks sweet! Desperately want a solution for the current lame boot lid. Looks hella' lot of work Quote Link to comment Share on other sites More sharing options...
