foxy Posted November 21, 2009 Report Share Posted November 21, 2009 Been practicing left foot braking in other cars for some years now, but as im driving the lupo harder and faster I decided to give it ago in that the other day. Problem is when you press the brake it cuts the throttle, does anybody know if its possible to turn this off on the ECU? Link to comment Share on other sites More sharing options...
JamesU Posted November 21, 2009 Report Share Posted November 21, 2009 Does it do it in non-gti's? Sorry, i dont know what car you drive...I love double clutch atm! Link to comment Share on other sites More sharing options...
nfbr Posted November 21, 2009 Report Share Posted November 21, 2009 Been practicing left foot braking in other cars for some years now, but as im driving the lupo harder and faster I decided to give it ago in that the other day. Problem is when you press the brake it cuts the throttle, does anybody know if its possible to turn this off on the ECU?Nope, Can't be turned off with either VAS or VAGCOM.The only way to do it is by re-wiring the connector on the brake pedal switch only to opperate the brake lights. It's a 4 pin switch so should be relatively easy to re-configure.sI love double clutch atm!Your car has a Synchromesh. It shouldn't make any difference whatsoever. 1 Link to comment Share on other sites More sharing options...
foxy Posted November 21, 2009 Author Report Share Posted November 21, 2009 Cool, cheers Al. I shall look into that. 1 Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted November 21, 2009 Report Share Posted November 21, 2009 If you change the wiring for the brake light switch it will work for a few days then it will do something very odd, the system learns a new route and then starts to apply the double input safety cut off.The one and only way to get around this is to remove the connector from the switch and wire a new totally seperate system and seperate wires to the rear lights. thats the only way to stop the ecu taking over. Link to comment Share on other sites More sharing options...
nfbr Posted November 21, 2009 Report Share Posted November 21, 2009 How about wiring a switch inline to cut off the feed to the ECU so it can be switched off when hooning about and switched back on for daily driving? Link to comment Share on other sites More sharing options...
Philplop Posted November 21, 2009 Report Share Posted November 21, 2009 I tried gentle left foot braking once.I nearly went through the windsreen. 3 Link to comment Share on other sites More sharing options...
Naif Posted November 21, 2009 Report Share Posted November 21, 2009 heel + toe > left foot... Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted November 21, 2009 Report Share Posted November 21, 2009 How about wiring a switch inline to cut off the feed to the ECU so it can be switched off when hooning about and switched back on for daily driving?Tried that, the ecu picks up another signal feed somehow, even the factory isnt sure how they do this but it does! THE only way is to rewire a new brake system. Link to comment Share on other sites More sharing options...
CasperGTI Posted November 21, 2009 Report Share Posted November 21, 2009 Change the ecu... I dont have any issues with it at all 1 Link to comment Share on other sites More sharing options...
nfbr Posted November 21, 2009 Report Share Posted November 21, 2009 You bugger john... Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Change the ecu... I dont have any issues with it at all Only the cost of the ECU and setting up!!!!!! 5 metres of wire is cheaper hehe. Edited November 21, 2009 by 1 Litre Screamer Link to comment Share on other sites More sharing options...
CasperGTI Posted November 21, 2009 Report Share Posted November 21, 2009 ^ that is very true Link to comment Share on other sites More sharing options...
99hjhm Posted November 21, 2009 Report Share Posted November 21, 2009 Right... Why is anybody even trying to left foot brake???If you watch motorsport, even drivers with sequential changes, clutch on the down change to save the gearbox. ie right foot brake.Double de-clutching.... Didn't know they made a pre-war Lupo?? Although I do sometimes double de-clutch, and blip the throttle on the down change when pulling off the road on to my drive,like a ****! Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Right... Why is anybody even trying to left foot brake???If you watch motorsport, even drivers with sequential changes, clutch on the down change to save the gearbox. ie right foot brake.Double de-clutching.... Didn't know they made a pre-war Lupo?? Although I do sometimes double de-clutch, and blip the throttle on the down change when pulling off the road on to my drive,like a ****!Left foot braking allows you to stay on the power but restrict the speed a small amount then once you lift off the brake it still has full power input. Compared to having to lift off the power, move foot across and brake, move foot across and the power then wait for the engine to respond. Its a true racing thing and to be honest shouldnt be done by anyone that cant handle a car in slide, it is dangerous if you get it wrong but very effective when done properly.As for the double clutching, 99hjhm is correct, its actually doing more harm than good. The extra wear on the clutch isnt worth it as gearboxes are now made with syncromesh so no old crunch boxes. Edited November 21, 2009 by 1 Litre Screamer Link to comment Share on other sites More sharing options...
Philplop Posted November 21, 2009 Report Share Posted November 21, 2009 I did it whilst waiting in a long queue of traffic, was just stretching my right leg I think, so thought I'd let the car roll forwards and brake with my left foot. Didn't work very well, never tried again. Link to comment Share on other sites More sharing options...
PaperWeight1 Posted November 21, 2009 Report Share Posted November 21, 2009 Left foot braking on open roads isn't necessary IMO, if you're driving that hard you should be on a track.I've played around with it before and it's pretty easy to slide if you're not very 'good' with your left foot.Only thing worth doing if you want to save the box is blipping the throttle on downshifts to match the revs and give the synchros less work. 1 Link to comment Share on other sites More sharing options...
99hjhm Posted November 21, 2009 Report Share Posted November 21, 2009 I see it useful when high speed cornering to balance the car, and save you coming off the throttle, will vary between cars, and maybe in hill climbing... I just don't see a use for it on the road. Link to comment Share on other sites More sharing options...
pro3mark Posted November 21, 2009 Report Share Posted November 21, 2009 Only thing worth doing if you want to save the box is blipping the throttle on downshifts to match the revs and give the synchros less work.I like to do that a fair bit, got used to it from my sport, but the throttle was so slow! Link to comment Share on other sites More sharing options...
nfbr Posted November 21, 2009 Report Share Posted November 21, 2009 Double de-clutching.... Didn't know they made a pre-war Lupo?? Although I do sometimes double de-clutch, and blip the throttle on the down change when pulling off the road on to my drive,like a ****!ROFL, Great way of explaining it. I've already tried to explain about the syncromesh over msn but he's mechanically inept. Link to comment Share on other sites More sharing options...
foxy Posted November 21, 2009 Author Report Share Posted November 21, 2009 (edited) Right, you bunch of retards are going to get both barrels from me in the morning. Im a little drunk right now, but thanks to Al and 1 litre Screamer for your EDUCATED answers. Edited November 22, 2009 by foxy Link to comment Share on other sites More sharing options...
nfbr Posted November 21, 2009 Report Share Posted November 21, 2009 Barrels mate? What you been drinking lol. I got some Baileys with a hint of Coffee here. Link to comment Share on other sites More sharing options...
Silver! Posted November 22, 2009 Report Share Posted November 22, 2009 1.0 Arosa was the same. Link to comment Share on other sites More sharing options...
billy Posted November 23, 2009 Report Share Posted November 23, 2009 The only way i can change down into 3rd is double clutch with blip, as am sure syncro gone/warndone the oil, alignment thingy but no better. so just a habit know. coz if you miss that change i end up in neutral till i get chancefor 2nd thenbill Link to comment Share on other sites More sharing options...
pdt Posted November 25, 2009 Report Share Posted November 25, 2009 i left foot braked to try and scare some dick behind me; i only tried to touch it a tiny bit to turn the brake lights on cause i was doing 70 on a dual carriage way. will never do it again though as i nearly locked the wheels... think cause my left leg is used to pushing harder on the clutch i couldnt gauge the pressure well enough. scary stuff... Link to comment Share on other sites More sharing options...
