3rd time lucky
Mitchell
thanks i'm going back up tommorow to re assemble the cradle suspension, may start the shell
Still not happy with camera pics as true colour is much richer and darker.
Mitch mate thats amaising. Wish id gone to these levels when i had my engine out now!
Theres so much room behind the scuttle panel now its cut away completely removed. How does the plastic part that clips to the window fit now? or do you have a modified one of those?
Your up to something with the engine mounts again i see, still using the custom front one? Id like to see the rear ones, because if there anything like the front one, there going to be a work of art again!
RE the facebook comment.... Do you need a cooler set up?
John
Well I'm thinking 4 weeks or so, depends really I need to remove all the vw ecu wiring from the engine bay harness as its redundant and leave only lighting ,horn,brake fluid level sensor and wiper motor wiring, this all needs re routed /hidden, then it needs mapping again.
Cheers al, can honestly say I will never smooth a bay again.
Actually you wouldn't know what diameter the top Rad hose is?
Christ Mitchell sir.
That is some work in that bay.
truly sterling though, a credit to your skills mate.
I have heard through the grapevine about a certain set of wheels
I've been stashing away in hope of getting another lupo.
if all is true. then great choice of hoop, perfect for your car.
yeh if they come off ! inside has colour now along with a few bits of trim, :)
