BASIL BRUSH Posted July 1, 2009 Report Share Posted July 1, 2009 Can anyone give any advice on removing the door panel? Quote Link to comment Share on other sites More sharing options...
FLO7LXJ Posted July 2, 2009 Report Share Posted July 2, 2009 Why do you want to remove it? (speakers are quite hard to do unless you have done them befor you need addaptors for them)It's quite a job (getting it back on)You will need a few star keys to get it off and a bit of force, there are star head screws on the bottom, sides (!) and center (not quite sure as I am not with my car)you have to remove these about 6 I think then unclip the top edge, you can not remove the door card compleatly if you have electric windows unless you disconnect them (if you have windy windows then you will need to take the top cover off (if there is one) then undo the star head screw and the handel should come off.beaware of the door lock when removing and refitting as I did not get mine back quite right and had to pull the door card off again.I will take a look at my car when I get home and update you (I love mobile broadband).hope this helps Quote Link to comment Share on other sites More sharing options...
