arosajoe Posted June 6, 2009 Report Share Posted June 6, 2009 my arosa 1.4 tdi driver side window switch has stopped working, any suggestions to what it could be?symtoms: windoes still work when you use the key and the passenger switch still works, when you press either window switch on driver side i can hear it clicking but nothing happens, also the lock and un lock button on the switch uni works fine. i took one switch apart to check for corrosion but it was all ok, any suggestions please?? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 7, 2009 Report Share Posted June 7, 2009 Link Quote Link to comment Share on other sites More sharing options...
arosajoe Posted June 7, 2009 Author Report Share Posted June 7, 2009 yeah tried this, took apart but no corrosion present, any other reasons why my windows wouldn't work? Quote Link to comment Share on other sites More sharing options...
nfbr Posted June 7, 2009 Report Share Posted June 7, 2009 Try swapping the connectors over on the bottom of the window switches and see if the other switch operates the window which currently isn't working. Quote Link to comment Share on other sites More sharing options...
