Cams for a lupo gti?
twoggy
Do you know how much work is involved in chaging the camshafts on the gti?
The specific tool to align the camshafts to install them is only from VW and is priced at approx £80
I think ttttada has a set fo schricks in his car, ask him mabe?
Prepare your wallet!
John
Edited by CasperGTI
The question is, why????
Unless everything else is optimised before, changing the cams is only going to make you go backwards, loosing driveability. Do you have a ported head, exhaust, induction, ECU remap???
Im taking my loop off the road this summer to carry out engine work. ported and polished head, BMC with a good cold air feed and a full AAS exhaust including sports cat and manifold. My cousin is a master tech at VW so im assuming he can get hold of this tool for adjusting the camshafts. Just wondering wich cam would suit the GTI engine the most? Then of course it would need a remap.
Its the same for any camshafts fella. You align and belt them up and and turn the crank to get the correct timing. Done it with plenty of my cars.
Catcams offer camshafts that can work with a base mapped ecu. They focus on when the car is on higher cam area making the car still good for day to day driving. Getting the car on Saturday fella selling my Audi TT :)
I got plans such as exhaust & manifold, 2.0 inlet, enclosed air filter, either flash base map or stand alone ecu, coilovers, big brakes, stripped with buckets.
Its going to weigh as much as a bag of Walkers crisps and shock a couple of tasty motors too :D
Edited by twoggy
Yer... You don't have to tell me, I build race engines for a living! Not VW, but Changing the cams in all engines is the same.
Also, I would go further if fitting different cams, Unless they are ground on the same lobe centers, the timing will be wrong... You need to degree the sames by either checking the lift on overlap @TDC or checking the MOP (point of full lift in degrees past TDC). Can the sprockets be adjusted, or are vernier sprockets avaliable.
Only trying to help.
Yeah mate agree with you there. Not sure about the pulleys, will check up and let ya know ;)
Ok, There are no vernier pulleys available for the AVY head, believe me ive looked at it for mine. You could get an exhaust one, but not an inlet one. You would need to build a hybrid engine with a different head and cam set up.
Fitting the camshafts in the engine is the easy bit. Its gettign the VVT sprocket back on that is the hard bit. The VVT sprocket is a sprung loaded over centre cam fed by oil pressure through the centre of the inlet cam. THIS HAS NO WOODRUFF KEY, So can go on in any position on the camshaft.
You need to get the specialist tool, which holds the end for the inlet cam to the cam housing. Then you need to put the sprocket on with the torque disc and the locking pins to align the camshaft with the sprocket, and the sprocket with the cam carrier. there is a centre through bolt that has oil channels in it and that must be correctly tightened so it aligns with the oil feed from the centre of the camshaft.
Heres a few pics to explain it.
John
John
Dam that is a bit more work than the normal camshaft lol.
Thanks for the help fella. Good to see that you guys have the same interests at heart ;)
Welcome to the ownership of the gti! you should learn these points very fast about the gti.
1 - Doing anything to the engine is expensive.
2 - Most parts have to be custom made or are only specific to this engine
3 - The mechanics are far too complexed for there own good!
4 - Specialist tools needed all over the shop!
Mabe this is what makes them so niche?
Twoggy - were you the guy that left a comment on E38 to me about charging your car? Told you it was a lot of hassle!
John
John
Lol yep. just got back from doing the deal with my Audi for the Lupo. They rev well dont they!! ha befroe i knew it i was nearly off the clock :huh:
  • 2 years later...
  • 3 weeks later...
I have a pair of schrick cams for sale
that i had in my Polo GTI
in combination with FPR of 3,8bar it is a lot of difference believe me ;)
plus BMC car was doing 15,5 with reaction, time of car was 14,9 on 402m lot of turbo cars have been in mirror
if some on is interested PM me
this is spec for cams
Edited by Petar001
Can LUPO GTI fit the Schrick 268 CAM?? I am interested it.
and to answer to this question 268 schrick cam for GTI does not exists
because GTi has variable intake and ONLY avaible schrick cam is first on picture
other two are for EX
  • 3 years later...
John
i was wondering where did you get these cam shaft locking tools from? i have been looking all over the web for them and i cant find a place where they sell them. i rang vw adn they wouldnt sell me a set and i really need them to re-built my engine. And if you still have them would you be intrested in selling them to me??? please do get back cheers.
