richardn Posted January 25, 2009 Report Share Posted January 25, 2009 does anyone on here know how to change a crank sensor,just need to know location etc.any help will be good Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 25, 2009 Report Share Posted January 25, 2009 on? Quote Link to comment Share on other sites More sharing options...
richardn Posted January 26, 2009 Author Report Share Posted January 26, 2009 sorry 1.4 16v lupo Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted January 26, 2009 Report Share Posted January 26, 2009 Did i not tell you how to do it a few months ago? or was that someone else?John Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted January 26, 2009 Report Share Posted January 26, 2009 Sorry someone else....Search finds this:You wont see it though mate, Its inbetween the engine and the gearbox. inface, tight inbetween the engine and the back of the flywheel.If you go down the back of your engine, you will find a little plastic cover on the block, gearbox end of the engine, the wire for the sensor travels trough there, i think you canget to the sensor from there. You will need to take the inlet manifold and throttle body assembly off to get to it though.If you cant get to the bolt (allen key) then your need to take off the gearbox, clutch, and flywheel to get to it. Its not the most fun thing to get to!John Quote Link to comment Share on other sites More sharing options...
richardn Posted January 27, 2009 Author Report Share Posted January 27, 2009 no wouldnt have been me you told Quote Link to comment Share on other sites More sharing options...
paddy Posted January 27, 2009 Report Share Posted January 27, 2009 If you disconnect the battery, remove the starter you should get it from their that's how mines was done Cheers paddy Quote Link to comment Share on other sites More sharing options...
Kid Icarus Posted November 27, 2011 Report Share Posted November 27, 2011 Does the same go for a GTi then? I need to know the location and the least amount of work to get to it and then replace please? Quote Link to comment Share on other sites More sharing options...
Snowy Posted November 15, 2013 Report Share Posted November 15, 2013 Is this the same procedure on a 1.0l auc engine? Quote Link to comment Share on other sites More sharing options...
danoid Posted November 15, 2013 Report Share Posted November 15, 2013 I created a guide a while ago for my 1.0http://danstyan.co.uk/wp-content/uploads/2013/09/VW-Lupo-Camshaft-Sensor.pdfAlways get confused if camshaft is crankshaft, seems ot have multiple names Quote Link to comment Share on other sites More sharing options...
