sam bignell Posted December 10, 2008 Report Share Posted December 10, 2008 when i turn the rear washer on, my car seems to be having a wee down by the passenger door/arch!If the water does come onto the screen its at lower pressure.Whats gone wrong? Sam Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 10, 2008 Report Share Posted December 10, 2008 The pipes can crack in icy conditions Quote Link to comment Share on other sites More sharing options...
tomflyer Posted December 10, 2008 Report Share Posted December 10, 2008 (edited) most likely you've popped the washer pipe off next to ther reservoir the nozzle was probably frozen forcing pressurized water down it and that's one of the weakest places to go just trace the pipe from the water pump on your washer bottle back till you find the pipe off and pop the pipe back on easy fix.(if you dont want it to pop off again put a jubilee or similar type clip around it clamping it onto the pipe but beware that if it happens again the pipe will pop off somewhere else along the line)hope this helps tom Edited December 10, 2008 by tomflyer Quote Link to comment Share on other sites More sharing options...
sam bignell Posted December 11, 2008 Author Report Share Posted December 11, 2008 Thanks I'll have a look over the weekend. Where I'm living atm its around -5 at night Quote Link to comment Share on other sites More sharing options...
mugz_dubz Posted December 11, 2008 Report Share Posted December 11, 2008 ive had this at wrk loads most of time its coz of icy condistions but otheres its coz of the boot bein opened and shut so check the pipe wer it runs in to the boot aswell dude Quote Link to comment Share on other sites More sharing options...
jon_273 Posted December 11, 2008 Report Share Posted December 11, 2008 If you put more screenwash in then it will freeze at a lower temperature, which will stop the pipe popping off in future.Also GTi's and Sports have heater washer jets! They come on with the rear window demister Quote Link to comment Share on other sites More sharing options...
sam bignell Posted December 12, 2008 Author Report Share Posted December 12, 2008 If you put more screenwash in then it will freeze at a lower temperature, which will stop the pipe popping off in future.Also GTi's and Sports have heater washer jets! They come on with the rear window demister I didn't know this, next time its cold I'll give it a goCheers Quote Link to comment Share on other sites More sharing options...
bluebottle Posted May 9, 2013 Report Share Posted May 9, 2013 I've just had this same problem, following the last very cold spell (only just got around to fixing it). I found the location of the dislodged joint (thanks to this site) hidden behind the nearside plastic rear boot/shelf support trim, just above the rear n/side wheelarch. There is a joint there (along with an electrical multi-block connector) wrapped in some grey foam - the joint had been pushed apart completely, so must have been thoroughly frozen. I thought I had fixed the problem with that repaired, but unfortunately the cold had also ruined the rear wiper motor/spray nozzle assembly - took that apart and found the small metal pipe that goes through the spindle had also frozen and was damaged beyond repair - new wiper motor required, but at least I can fix it myself. Quote Link to comment Share on other sites More sharing options...
jeeprk Posted May 11, 2013 Report Share Posted May 11, 2013 Had the same problem as described. It was the pipe connection in the panel by the passenger rear seat. If you take the cloth panel (or card ) just above the storage box you will see the pipe coming from the washer bottle has a connector that connects to the pipe to the rear wiper motor. If you check you should notice one of the pipes was not connected (or looses) to the connector hence a wet floor and no water coming out from the rear wiper! I connected pipe and used emergency tape to wrap round the connector and had no wee since!Hope this helps. Quote Link to comment Share on other sites More sharing options...
