Mitchell Posted November 6, 2008 Report Share Posted November 6, 2008 right the ahw engines are pants and long in the tooth some being 10 years old now and replacements are a risky game as you never know what your gonna get and so many it seems suffer from emmisions failure caused by cylinder bore wear, i myself have had 3 with this problem and all were 60/70 thousand milers.now then, the ahw engine is used in most low cc model vw's inc the golf however the golf block is different the starter motor is on the front whereas the lupo /polo is at the rear, i know this as i bought the wrong one thinking ahw all shall be well,think again.anyway bby.the bby is basically the same engine allbeit fitted with independant coil packs for each cylinder, a different inlet manifold with the oil breather return located after the throttle body and obviously the wiring is different.i sat my ahw next to it and basicaly swapped everything over one thing again that the ahw does not have that the bby does is a breather in the cam carrier, this i have capped for now as the crank case breather will suffice but i may route it into the air box in a few datys time.now then the beauty thing about this engine is that they were available from 2003 onwards maybe late 2002 up until 2005 so low mileage examples are around.if anybody wants some queestions answered please post them here, mitch. Quote Link to comment Share on other sites More sharing options...
MattyA Posted December 5, 2008 Report Share Posted December 5, 2008 Good info Mitch. Quote Link to comment Share on other sites More sharing options...
12loop34 Posted January 1, 2009 Report Share Posted January 1, 2009 hi, my sports burning oil, if i found a replacement engine. . . what code would it need to be, or what code engine would fit?would 1.4 s blocks fit with the sport head? and what wiring would i have to do on any engine transplant?my engine code is an AFK,cheers for your help Quote Link to comment Share on other sites More sharing options...
Janebrink Posted January 13, 2009 Report Share Posted January 13, 2009 (edited) Hi!Just bought a Lupo 1.4 75bhp ´99 with a broken engine... So what you are saying is that I should look for an engine with the enginecode BBY? And I don't need to use my cylinderhead from the broken engine? Does it matter if it originally was mounted with an automatic or manual tranny?The original engine gave up after running out of oil, and stopped due to the "suddenly increased friction", so I don't think there is so much left to use in that one... Regards,Anders. Edited January 13, 2009 by Janebrink Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 13, 2009 Author Report Share Posted January 13, 2009 hello, i'm currently removing the above engine from the lupo as i'm moving forward with my build so it will be for sale in a week.runs exceptionally well and is a straight in job. Quote Link to comment Share on other sites More sharing options...
Janebrink Posted January 13, 2009 Report Share Posted January 13, 2009 Well, I live in sweden so the shipping is probably more expencive than a new engine.... :S Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 14, 2009 Author Report Share Posted January 14, 2009 lol, in that case yes the bby engine is the one to have. Quote Link to comment Share on other sites More sharing options...
dxg Posted January 14, 2009 Report Share Posted January 14, 2009 I thought BBYs had a poor reputation for going through piston rings? Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 15, 2009 Report Share Posted January 15, 2009 I thought BBYs had a poor reputation for going through piston rings?Never heard that said about the BBY, I think that was a problem of the older engines .The BBY was used in Lupos since at least September 2002, the Lupo 1.4SE used it (available from '52 to '03 reg). If you can find a 1.4SE in a breakers then it will most likely be a BBY engine . Quote Link to comment Share on other sites More sharing options...
Janebrink Posted January 29, 2009 Report Share Posted January 29, 2009 Hi again!For those who are interested out there, I can tell that I bought a BBY from a Skoda Fabia ´04 and it fitted after some exchanging of parts from my old AHW. For example, I had to loosen one tensioner to the cambelt so I could dismount the plastics surrounding it. That needet to be switched among other things. but it took me a couple of hours, and now I have an engine that is about 4 years old with a milage of 20000 miles. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 29, 2009 Author Report Share Posted January 29, 2009 I thought BBYs had a poor reputation for going through piston rings?the ahw is the same motor as bby but older and the risk of a poor ahw is higher than bby . Quote Link to comment Share on other sites More sharing options...
Lupita Posted December 29, 2010 Report Share Posted December 29, 2010 Hi, I have the same problem. I own '99 Lupo SE and I am looking for an engine replacement. My engine code is AKQ and I have an opportunity to buy BBY engine with all the wiring. As far as understand from previous posts in this thread it should fit, or should I keep looking for exactly the same AKQ engine?Please help a lady... Quote Link to comment Share on other sites More sharing options...
Janebrink Posted December 29, 2010 Report Share Posted December 29, 2010 As long as your engine is a 75bhp 1.4 litre, it should be just fine. It's only one thing I havent fixed yet, and that is the pipe coming out of the valvecover. Don't really know where that should be connected... I've connected it to the airfilterbox as for now... Must look into this soon. But go ahead and make the switch. Don't think you'll be having so much use for the wiring. Cheers and good luck! Quote Link to comment Share on other sites More sharing options...
Lupita Posted December 29, 2010 Report Share Posted December 29, 2010 Answer to my own question:My boyfriend took the block from the broken Lupo AKQ engine and went to compare it with BBY and guess what - they are different... At the and where the gearbox should be attached to the engine, BBY has more fitting holes than AKQ and the fitment of the starter in different...I'm already loosing hope to find a new engine Quote Link to comment Share on other sites More sharing options...
Mitchell Posted December 29, 2010 Author Report Share Posted December 29, 2010 sounds like you have a bby from a golf. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted December 29, 2010 Author Report Share Posted December 29, 2010 as said before the differences are only in the starter motor mounting position, any replacement for a lupo must have the starter mounting to the rear of the block. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted December 29, 2010 Author Report Share Posted December 29, 2010 As long as your engine is a 75bhp 1.4 litre, it should be just fine. It's only one thing I havent fixed yet, and that is the pipe coming out of the valvecover. Don't really know where that should be connected... I've connected it to the airfilterbox as for now... Must look into this soon. But go ahead and make the switch. Don't think you'll be having so much use for the wiring. Cheers and good luck!it's just a breather return it into theairbox, or leave blanked. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted December 29, 2010 Report Share Posted December 29, 2010 Get the airbox off the BBY if you can, as it will have a stub on the right hand side for the extra breather pipe. You can see it in this pic: Quote Link to comment Share on other sites More sharing options...
jamielupo Posted January 12, 2011 Report Share Posted January 12, 2011 does the same apply for engines with the code bky as its seem to have the same spec as the bby and ahw Quote Link to comment Share on other sites More sharing options...
chris c Posted January 13, 2011 Report Share Posted January 13, 2011 just a bit of extra info i have a lupo with an ahw in it i bought an auh out of an arosa sport and pretty much everything swaps over easily inlet manifold ect not started mine yet but that will be coming soon Quote Link to comment Share on other sites More sharing options...
MARKY46 Posted March 3, 2011 Report Share Posted March 3, 2011 Is there a difference with the BBY engines??I've found a replacement AHW engine for my car but the starter motor was in the wrong position, at the front instead of the back, and I was wondering if this is the same with the BBY engine and if so, how do you determine which BBY engine will go into my Lupo??Is there a difference in codes?? A friend will be getting me the engine from his contacts in the south of England and we are in Glasgow and he won't be able to see the engine before he gets it so all info will be helpful.Regards... Quote Link to comment Share on other sites More sharing options...
MARKY46 Posted March 7, 2011 Report Share Posted March 7, 2011 BBY is not an option for replacing the AHW engine. It's completely different. Is the AUA an option??Anyone out there swapped an AHW with an AUA?? Quote Link to comment Share on other sites More sharing options...
MARKY46 Posted March 8, 2011 Report Share Posted March 8, 2011 Has anyone out there replaced an AHW engine with and AUA engine??? Quote Link to comment Share on other sites More sharing options...
Ell.s Posted March 8, 2011 Report Share Posted March 8, 2011 Never heard that said about the BBY, I think that was a problem of the older engines .The BBY was used in Lupos since at least September 2002, the Lupo 1.4SE used it (available from '52 to '03 reg). If you can find a 1.4SE in a breakers then it will most likely be a BBY engine .So does that mean the engine in my 04 1.4s is a BBY? Quote Link to comment Share on other sites More sharing options...
chrisash32 Posted January 30, 2012 Report Share Posted January 30, 2012 I know this is an old thread....However I just wanted to add that I have completed the AHW to BBY Conversion now and I am pleased to report that all is working fine.What mitch says about finding low mileage BBY is quite true! Picked myself up a bargain engine with only 13k on the clock One thing to add, I needed to block off the EGR outlet on the side of the BBY engine as my AHW has its EGR connected to the exhaust manifold. All is good though as VW sell a blanking plate for this. You need the plate, two screws and a gasket - costs about £5.I also couldn't find the cam case breather too until it spat in my face! Its on top of the engine next to the top right engine cover screw. Thanks go to mitch for the advice!Chris Quote Link to comment Share on other sites More sharing options...
