akbarirfan Posted February 18, 2008 Report Share Posted February 18, 2008 Hi Guys n Gals,I have recently purchased an Alpine head unit..the power part of the loom has a red wire going to it and a blue wire (for the antenna). I have a yellow wire that needs to be connected to the positive charge, I have a feeling I will have to swap the red and yellow anyway, can anybody confirm this please? If that is the case will I have to connect the red wire to the positive? Or can I skip this part?Were is the best place to connect the ground wire to?If I swap the red wire and the yellow wire, do not connect the red wire to the battery, and ground the black wire, will it work like that?Thanks!! Quote Link to comment Share on other sites More sharing options...
M1 Lupo Posted February 19, 2008 Report Share Posted February 19, 2008 I have a 9815RB somewhere here.Connect the Black to body ground. Yellow to the ignition live and Red from a 20a fused feed from the battery. Quote Link to comment Share on other sites More sharing options...
akbarirfan Posted February 19, 2008 Author Report Share Posted February 19, 2008 Thanks M1 LupoWhat awg wire do you advise for taking the red to positive terminal?How do I hook up a fuse?Thanks. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted February 19, 2008 Report Share Posted February 19, 2008 12AWG will do it at the distance you have to travel. Quote Link to comment Share on other sites More sharing options...
akbarirfan Posted February 19, 2008 Author Report Share Posted February 19, 2008 Is there a hole from behind the headunit to get to the enigne bay?Thanks. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted February 19, 2008 Report Share Posted February 19, 2008 If you feed the cable down the side of the dash behind the headunit it will bring it out in the passenger footwell.The grommet in the o/s of the engine bay contains the main wiring loom.If you feed some cable through that, then tie your headunit cable to this, and then pull it through the bulkhead. Quote Link to comment Share on other sites More sharing options...
