openrooflupo Posted October 31, 2007 Report Share Posted October 31, 2007 (edited) Hi guys recently the radio in the lupo started cracking while listening, followed the next day by NO radio, tape deck works tho.. Any ideas ? do the aerials ever fail or is it head unit ? Also if i replace the stereo how do i get the original out ? Any pointers appreciated Edited October 31, 2007 by openrooflupo Quote Link to comment Share on other sites More sharing options...
RobG Posted November 1, 2007 Report Share Posted November 1, 2007 Hi guys recently the radio in the lupo started cracking while listening, followed the next day by NO radio, tape deck works tho.. Any ideas ? do the aerials ever fail or is it head unit ? Also if i replace the stereo how do i get the original out ? Any pointers appreciated Getting the old radio out is easy, there are two thin slots in the lower section of the face, on either side, you can either get keys from halfords/vw dealer, or improvise with a cut up credit card. slide the keys into these slots then pull out firmly but gently (I stick my fingers in the casette slot and pull). If you've aligned the keys right it'll just slide straight out. You'll be able to check see if your aerial lead's fallen off the back or not. Before you unhook the speaker/power connectors removing the head unit, make sure you've got your code handy for when you plug it back in Quote Link to comment Share on other sites More sharing options...
openrooflupo Posted November 2, 2007 Author Report Share Posted November 2, 2007 Getting the old radio out is easy, there are two thin slots in the lower section of the face, on either side, you can either get keys from halfords/vw dealer, or improvise with a cut up credit card. slide the keys into these slots then pull out firmly but gently (I stick my fingers in the casette slot and pull). If you've aligned the keys right it'll just slide straight out. You'll be able to check see if your aerial lead's fallen off the back or not. Before you unhook the speaker/power connectors removing the head unit, make sure you've got your code handy for when you plug it back inCheers for that will investigate. Quote Link to comment Share on other sites More sharing options...
openrooflupo Posted November 3, 2007 Author Report Share Posted November 3, 2007 Tested the unit once i got it out, tried it with different aerial and still no joy,so went out and bought a new sony stereo with cd player yay !! sounds great now Quote Link to comment Share on other sites More sharing options...
