Trenthamfolk Posted April 17 Report Share Posted April 17 Hi all, Wonder if anyone can help. I have a 2005 GTI Japanese Import, and after a winter in the garage I have started to get a check engine light reading codes P0010 Camshaft Position Actuator, and P0045 Evap Purge Valve Shorted. I am using a cheap Amazon scanner and think these codes are being iterpreted incorrectly, aspecially as we're naturally aspirated. The car drives fine with the light on, and if I clear the codes the car is fine, until I hit reverse and the light comes on again. I have replaced the battery and the problem persists, so this leads me to believe it is a wiring/voltage/grounding instability issue. I want to check the gearbox earth strap first as this seems most likely culprit, but I cannot for the life of me seem to locate the earth strap/connector. Can anyone tell (or show) me where on the gearbox it locates, and where it attaches to the chassis? TIA! Dan 🙂 Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 10 Report Share Posted May 10 Suspected bot? Quote Link to comment Share on other sites More sharing options...
