Lupo maintenance
Thedriver
Hello everyone! These days I removed the throttle and cleaned it with brake spray, because I don't have the special one for the throttle. It was quite dirty and now the car runs completely differently, in a good way. I would like to clean the flow meter too, but I can't find it. Can you tell me where it is and give me a picture? I couldn't find anything on the net that would help me... (engine: 1.4 16v 75hp AUA)
You spray it when it's running and it might clean a bit of the inlet manifold, don't take it off as you really don't want vacuum leaks
Ok, but where is it? And one more thing, after I removed the engine cover, I saw some kind of sensor that goes into the rocker cover. I removed it and besides the oil, it also had some sludge on it that I cleaned. What sensor is that? Does it measure the oil pressure or...?
Fairy liquid mixed with kerosene or diesel. Or to remove Diesel engine oil gunge residue, fairy mixed with cellulose thinners. No other washing up liquid works, only green fairy. I don't know why 🤷🏻‍♂️
But in both cases, low-medium revs, not a hot engine and a very light drizzle/spray into the air inlet to avoid flooding the engine. Does a nice job cleaning the backs of valves.
They changed the formulation of brake and clutch cleaner to stop bad people making "phosgene" out of the stuff...
  • 5 weeks later...
  • 3 months later...
