cj1 Posted May 2, 2022 Report Share Posted May 2, 2022 Hi, I think I've deduced the answer to this one myself, however is there a difference between the 1.0AUC Clutch and the 1.4 16v you'd use with an AFH engine? They're the same diameter from what I can see but different part numbers. I'm more curious as I think I've put a 1.0 clutch on my AFH and in less than 100 competitive miles it's now slipping! Not a topic I'm overly knowledgeable on so any informed input would be appreciated! Quote Link to comment Share on other sites More sharing options...
imaparana Posted May 3, 2022 Report Share Posted May 3, 2022 Comparing the two on autodoc the afh is 10mm larger diameter, suprised 10mm would make the difference in it slipping or not though Quote Link to comment Share on other sites More sharing options...
