_LM46 Posted March 28, 2022 Report Share Posted March 28, 2022 Hi, basically my Lupo starts fine first time from cold, but after it’s warmed up and turned off it doesn’t want to even attempt to start, the glow plug light comes on and goes off, the fuel pump doesn’t sound like it primed and then the starter just does one click, the battery is fine and brand new, alternator is fine and charges battery, it will start with a bump but won’t turn over on the key, has anyone had a similar experience or know what’s wrong? I’ve got a feeling it’s the fuel pump or maybe a bad ground on the starter, not 100% though so any info would be great, thanks Quote Link to comment Share on other sites More sharing options...
tigcraft Posted March 28, 2022 Report Share Posted March 28, 2022 Won’t be the fuel pump if it bump starts. I’d start by running a positive wire direct to your starter solenoid and see what the reaction is. Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 28, 2022 Report Share Posted March 28, 2022 Yeah good call... My guess it's a dodgy battery or main power fuse connection problem. Quote Link to comment Share on other sites More sharing options...
_LM46 Posted March 29, 2022 Author Report Share Posted March 29, 2022 So I got back from my 12 hour night shift went to start the car and there was no fuel priming sound and now glow plug light but the car turned over and wouldn’t start, after wiggling the wires on the steering column and taking the main fuses by the battery out it primed and started fine, ran up to temperature and went nice on the run home, and then when I got home it even restarted when hot! So I think you are right in saying the main fuses or maybe a bad connection Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2022 Report Share Posted March 31, 2022 109 relay Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 31, 2022 Report Share Posted March 31, 2022 I don't think you could bump start it if 109 is on holiday? It wouldn't run unless the vibration kinda makes the contact pass some current? Or maybe the ECU is trying to energise the glowplugs and that's killing the current? Ah, I dunno what I'm on about anymore...🤷🏻♀️ Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2022 Report Share Posted March 31, 2022 Glow plugs are overrated. Quote Link to comment Share on other sites More sharing options...
