Njhall Posted March 10, 2022 Report Share Posted March 10, 2022 Hi all! I wonder whether anyone might be able to give me some pointers on an issue I’m having with my 1997 1L petrol AER Arosa. When cold starting, the engine will catch quickly and run on start up, then die off in seconds. Each time I try to start it, the engine runs for a little longer, but roughly. Eventually, maybe after 8 attempts it will run and revert to running on a couple of cylinders before evening out and becoming able to drive. On frosty mornings it won’t run at all. From what I’ve read on the forum so far, it sounds like a fuelling issue. I have already replaced the fuel filter to no effect and am thinking about swapping out the coolant temperature sensor next… Question is, does anyone know the correct part number for the AER engine? Ones I’m finding online have a green plug, but the one in mine is Black as pictured. Any help, tips, tricks or advice would be massively appreciated! Cheers, Nick Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 10, 2022 Report Share Posted March 10, 2022 Yeah sounds like temp sensor. They're only a few quid from vdub direct... worth getting OEM if you're gonna keep the car 👍🏻 Quote Link to comment Share on other sites More sharing options...
Njhall Posted March 10, 2022 Author Report Share Posted March 10, 2022 Cheers MK2! Any heads up on what the correct sensor will be, or will the seat/ VW dealer know? Quote Link to comment Share on other sites More sharing options...
Njhall Posted March 21, 2022 Author Report Share Posted March 21, 2022 Thanks for the help! She’s starting like a dream now. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted March 23, 2022 Report Share Posted March 23, 2022 Earlier 4 pin temp sensor is 059 919 501 Quote Link to comment Share on other sites More sharing options...
