FraH2o Posted June 15, 2022 Author Report Share Posted June 15, 2022 Work on the links helped me, but not enough to achieve the desired goal. In the end I took apart the whole front subframe. This hitting point is really a nightmare for Lupo and polo owners. Which on the bar is located here So with everything disassembled, i checked the space and avaible material to nake another notch to achieve the right clearence for ARB Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 15, 2022 Report Share Posted June 15, 2022 Is it because the ride height has changed? May have been easier to move the ARB mounts? Nice work 👍🏻 Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 15, 2022 Author Report Share Posted June 15, 2022 2 hours ago, mk2 said: Is it because the ride height has changed? May have been easier to move the ARB mounts? Nice work 👍🏻 the ride height it's in my idea to drop about 10-11 cm. I've seen a Polo 6N2 owner mod the ARB mount on subframe to lower the ARB about 15mm. In this way he gain the clearence from chassis.....but there's the problem that these lowered ARB mounts will be too close to ground and an easy grinding point. Quote Link to comment Share on other sites More sharing options...
The Penguin Posted June 16, 2022 Report Share Posted June 16, 2022 On 2/21/2022 at 12:45 PM, FraH2o said: Yes mate, is a very strange color (my idea is to repaint in Ginster yellow like golf III) , in the meantime, making the roof black is a good compromise The only other thing I would add which I'm sure you know is that Roads can be rough outside the cities in Italy and wouldn't a soft suspension be better than coil overs and short springs 1 Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 20, 2022 Author Report Share Posted June 20, 2022 Another problem that has already been solved: with the rising of the entire engine group, the turbo has also risen and consequently also the downpipe that touch the subframe. So, I lengthened the dowpipe with a 15mm collar and modified the connecting tube to give it the right bend. At the beginning I just soldered a few points to check all. Finally I welded definitively After checking, the final welding 1 Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 20, 2022 Author Report Share Posted June 20, 2022 I didn't want take off the ARB, finally I notched and re-welded. I tried not to slice the box directly but to engrave and fold it, I made the tests with the bar, then I made 2 plates to close the various gaps. Today I rough up the weld and then proceed with the various layers of protective. Overall right side Overall Left side Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 25, 2022 Author Report Share Posted June 25, 2022 I continue with my "arlequin chassis". Rather than find a similar yellow lo LD1B , I painted with the first spray can that comes to hand. Usual procedure.Spray insulation, opaque white, color and final matt coat. Once the subframe has been assembled, I raised the wishbones with the jack and I made the various clearence tests. It's seems work good Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 25, 2022 Author Report Share Posted June 25, 2022 (edited) I start with the first drop approach to have a first check with the various notches. On the ARB with low level set-up I noticed that there are various schools of thought. Those who take it off, those who say that at certain heights it is useless, those who say that a good set-up is no longer needed. In my experience, the month in which she was disconnected from golf mk3 driving was imprecise and very dangerous. I have found the right clearances to make everything work quietly, and I am happy to know that I have the ARB in its place. Edited June 25, 2022 by FraH2o Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 29, 2022 Author Report Share Posted June 29, 2022 I continue with some little fix. I Replaced a broken clip on the support of the ecu Then I looked in vw for the bracket to support the lower intercooler pipe. No longer available. I have made it by myself Finally I closed all the cooling circuit Quote Link to comment Share on other sites More sharing options...
FraH2o Posted June 30, 2022 Author Report Share Posted June 30, 2022 Finally after 4 months I begin to see some results. I Reassembled the various crossbars before to remove the stands. In the meantime, the new tube for the CDA has arrived, Need some work to find a right location with enough air flow and safe from any rotating element. Pulled down but left on the wedges. I still have to work on the CDA airbox and on connecting the pipes between the diesel filter and the rail. Next week i'll try to turn it on (under VAG) and if everything is ok, I'll start to work on rear. Quote Link to comment Share on other sites More sharing options...
FraH2o Posted July 7, 2022 Author Report Share Posted July 7, 2022 I redid the last diesel pipes I Assembled the battery holder and linked it, i filled all liquids and then on the later the first re start I checked levels, left on to heat up and check all the various liquids and wait for the fan to start Everything isok and I finally made a diagnosis to see if everything is ok ... and apart from the airbags that are detached, for VCDS is good. All regular and in the parameters and no errors with egr and airbox elimination. And in a while I'll start wortk with the rear. Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 7, 2022 Report Share Posted July 7, 2022 Looking good 👍🏻 Check the fuel hose on the right side of the metal feed tubes, near the high pressure pump. It's the short L shaped pipe. It often rubs on the loom and can leak. About 80mm long. I would use the standard air filter, only because the intake air is cooler. Behind the intercooler, the intake air will always be warm, making the intercooler work extra hard. Looks nice though. Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted July 23, 2022 Report Share Posted July 23, 2022 (edited) hello, I'm French and I have almost the same Lupo as you and I'm a fan of what you did for work on yours it will be brand new for mechanics here are my two babies I am setting up here to follow the progress of the work, do you plan to modify the power https://www.golfiv.fr/autres-vag-f44/tdi75-il-est-la-youhouuuuuu-t109756.html Edited July 23, 2022 by tchouki85 1 Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted July 24, 2022 Report Share Posted July 24, 2022 are you going to install a central rear exhaust like on the GTI or the 1.4 100hp Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 10, 2022 Author Report Share Posted August 10, 2022 (edited) Hi Tchouki. Looks very good your Lupo.....is on 16" rims? Sorry for delay. I just finished yesterday to solve a big problem with gearbox of wife's Touran 1T2 From today i restart to work on my lupo Edited August 10, 2022 by FraH2o Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 10, 2022 Author Report Share Posted August 10, 2022 On 7/24/2022 at 8:41 AM, tchouki85 said: are you going to install a central rear exhaust like on the GTI or the 1.4 100hp Maybe in the future, I think is very hard to find a rear Sport bumper....😅 Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted August 10, 2022 Report Share Posted August 10, 2022 hello indeed not cool for the gearbox of the Touran, for my rims they are 15 "these are original rims they are called Ancora Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 11, 2022 Author Report Share Posted August 11, 2022 13 hours ago, tchouki85 said: hello indeed not cool for the gearbox of the Touran, for my rims they are 15 "these are original rims they are called Ancora yes it was very uncool, specially doing it on the floor...but norw is good. Wife is also happy, so i can continue with little LD1B I started the project swap of drums I use the whole group of golf MKIII with ABS sensor hosing It fit perfect Now i nedd to cut the brake line and add the last mk3 rubber hose to connect the mk3 calipers Now i continue to work removing standard spring and asborserber to star on work with ride height, to replace hand brake cables an start to roll arch. Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 11, 2022 Author Report Share Posted August 11, 2022 13 hours ago, tchouki85 said: for my rims they are 15 "these are original rims they are called Ancora They are very cool! are you on "standard" 195-45 15? Looks very good! 👌 Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted August 11, 2022 Report Share Posted August 11, 2022 yes the fitment is standard 195/45R15 78V too great the transition to disc braking for the rear axle is one of my future projects, if you can put as much information as reference type that would be great, you work very well Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 11, 2022 Author Report Share Posted August 11, 2022 6 minutes ago, tchouki85 said: yes the fitment is standard 195/45R15 78V too great the transition to disc braking for the rear axle is one of my future projects, if you can put as much information as reference type that would be great, you work very well Sure of this, just studing to modify the last part of metal fuel hose and add the flexible rubber to caliper. I'm looking for the flare tool for brake line. When i'ma ready i'll post all code for made this swap. Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted August 11, 2022 Report Share Posted August 11, 2022 great there I'm waiting for my camshaft bearings to be able to continue changing my timing belt so in the meantime I'm cleaning and condemning the Egr valve 1 Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 11, 2022 Author Report Share Posted August 11, 2022 29 minutes ago, tchouki85 said: great there I'm waiting for my camshaft bearings to be able to continue changing my timing belt so in the meantime I'm cleaning and condemning the Egr valve Egr deleting is ever the best way 🤣 Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted August 11, 2022 Report Share Posted August 11, 2022 it is deleted by computer since I am reprogrammed at 115hp Quote Link to comment Share on other sites More sharing options...
FraH2o Posted August 11, 2022 Author Report Share Posted August 11, 2022 37 minutes ago, tchouki85 said: it is deleted by computer since I am reprogrammed at 115hp Interesting, did you use VCDS to exclude it? Wow! 115 ps it's a very important increase of power....i think it's very funny!. Just ECU remapped or other? Don't you have fear for EXB gearbox? Some people tell me that is a fragile gearbox. Quote Link to comment Share on other sites More sharing options...
