Vasco Posted December 29, 2021 Report Share Posted December 29, 2021 The radiator fan on my 2004 Arosa 1.0l MPI isn't switching on. I've put 12v direct to the fan, and it runs. The next thing to check is the fuse. The fuse box next to the steering column only has a fuse for the ventilation fan, I can't find one for the radiator fan. It seems some Lupo and Arosa models have this fuse in a box attached to the top of the battery, but mine doesn't. Does anyone know where it is? Thanks. Quote Link to comment Share on other sites More sharing options...
arosa-beeftex Posted February 3, 2022 Report Share Posted February 3, 2022 Would have helped if you sent a picture of the engine bay and close up around the battery but anyway... The radiator fan operates of a 40A or 60A strip fuse. These are mounted in a box with two/three other fuses, and usually found on top of the battery. The holder could also have tow/three blade fuses on the outside. Quote Link to comment Share on other sites More sharing options...
