wallsworkshop Posted November 21, 2021 Report Share Posted November 21, 2021 Hi, both of my sidelights died on my Arosa the other day. I have bought replacements and installed them but still no luck. Checked fuses they’re all good, everything else that should light up does, apart from the front sidelights and I have no idea why. has anyone else come across this issue before? Many thanks Quote Link to comment Share on other sites More sharing options...
tigcraft Posted November 21, 2021 Report Share Posted November 21, 2021 Mine are same on my arosa too but not had time to look into it. Quote Link to comment Share on other sites More sharing options...
wallsworkshop Posted November 22, 2021 Author Report Share Posted November 22, 2021 It’s so annoying, whatever it is it’s not obvious everything seems as it should Quote Link to comment Share on other sites More sharing options...
Mattymdm Posted November 22, 2021 Report Share Posted November 22, 2021 Have you had a multi meter in the bulb holder and checked for a voltage? 1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 22, 2021 Report Share Posted November 22, 2021 What I've seen a few times on vdubs, not just Lupos- is the bulbs can get wet and there's an electrolytic reaction between the socket contacts and the bulb pins/wires. Have yiu tried scraping the contacts clean and lubing with loads of silicone grease? Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted December 3, 2021 Report Share Posted December 3, 2021 I guess thats voltage regulator fault, don’t your headlights change brightness from very dark to very bright when rpm changes? Quote Link to comment Share on other sites More sharing options...
