OBD scanner throws up 2 faults.
Shane56
Can you check the live sensor data - the temp sensors, ideally when cold before starting after overnight. Should be the same reading. Might be a dodgy temp sensor AND something else...
Assuming that the temp gauge reads normal once warmed up?
Edited by mk2
  • 3 weeks later...
My hunch is the infamous temp sensor. Especially since the guage keeps dieing. That company in Luxembourg that manufactured them really should have gone under years ago. The amount of global problems they have caused across the entire VAG group range is really unbelievable.
