Lupo 1.4 16v - EML Light on - P0407 - Powertrain Exhaust Gas Recirculation Sensor "B" Circuit low
Ray Singh
All,
My daughters 52 plate Lupo 1.4 16v has had the EML light come on. A quick OBD II diagnostic later and I can see the fault is P0407 - Powertrain Exhaust Gas Recirculation Sensor "B" Circuit low.
We have noted that the fuel consumption has increased.
Any ideas please?
To be sure where the problem comes from, more info is needed I guess... Not sure what else to suggest, as that code can be caused by quite a few things. Or a combination. But I'm fairly certain it has something to do with fuelling or air flow if that helps!
