benjbrooks Posted August 7, 2021 Report Share Posted August 7, 2021 Recently had the gearbox out to replace the clutch, after putting it back together the gear selector no longer self centres back to the neutral gate. It still centres left to right along the neutral gate. Looking under the gator I can't see where a spring should be. Am I missing something? 2000 Lupo S 1.4 16v Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted August 7, 2021 Report Share Posted August 7, 2021 There is no spring for up and down neutral position, just for left and right. I think the selector shaft of gerbox should leave it there. Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 8, 2021 Report Share Posted August 8, 2021 That'll be the little bolt in the linkage, that fits into the hole on the gearbox selector shaft. It slides on then you tighten the bolt. If the linkage isn't in the right position along the shaft, the stick will be resting closer to R/1/3/5 or 2/4. But if not that, it could be that the linkage mounting is twisted/incorrectly assembled- the bit that keeps the shifter mech steady as the engine provides torque. Quote Link to comment Share on other sites More sharing options...
lupo 1.7sdi Posted August 9, 2021 Report Share Posted August 9, 2021 You need to adjust the gear change mechanism Adjusting gear change mechanism.pdf Quote Link to comment Share on other sites More sharing options...
benjbrooks Posted August 10, 2021 Author Report Share Posted August 10, 2021 All sorted, it was the bolt on the linkage. Was holding it together but loose enough that I could slide. Thanks for the help guys 😊 1 Quote Link to comment Share on other sites More sharing options...
