BlacknYellow Posted July 14, 2021 Report Share Posted July 14, 2021 If there's anyone that is selling a 1.7 Sid Lupo I'm interested. I bought one recently but it came out faulty so I had to return due to the high cost for the repair. ( Faulty ECU). If anyone knows or sells one , please let me know . Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted July 15, 2021 Report Share Posted July 15, 2021 On 7/14/2021 at 5:44 PM, BlacknYellow said: If there's anyone that is selling a 1.7 Sid Lupo I'm interested. I bought one recently but it came out faulty so I had to return due to the high cost for the repair. ( Faulty ECU). If anyone knows or sells one , please let me know . I had a faulty ECU. cost me £30 from eBay for another unit that was tested! don’t write it off Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted July 15, 2021 Author Report Share Posted July 15, 2021 Was it a plug and play one? Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted July 15, 2021 Author Report Share Posted July 15, 2021 I've read that these ECU don't have immobilizer etc. And I can't seem to find anyone that can do a data transfer Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted July 16, 2021 Author Report Share Posted July 16, 2021 You can close this thread. Quote Link to comment Share on other sites More sharing options...
The Penguin Posted July 17, 2021 Report Share Posted July 17, 2021 A VW Lupo or Seat Arosa TDI is better in every respect, faster, better brakes, equal or better economy and able to be boosted by a re-map Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 19, 2021 Report Share Posted July 19, 2021 I disagree. More power than SDI yes. Quieter, no. More vibration. Same brakes. Less reliable engine but better gearbox than an SDI. @BlacknYellow i've never ever seen a failed Lupo ECU. They are well designed... Quote Link to comment Share on other sites More sharing options...
Rich Posted July 19, 2021 Report Share Posted July 19, 2021 Different brakes. Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 19, 2021 Report Share Posted July 19, 2021 6 hours ago, Rich said: Different brakes. Yup you're right. 256 vs 239mm. And hydraulic clutch vs crappy cable thing on the SDI. But the slave cylinders go. And so do the camshafts. And so do the balancing chains over 140k miles. But i like the tdi once you strip out the EGR and bung in a straight through pipe. Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted July 19, 2021 Author Report Share Posted July 19, 2021 7 hours ago, mk2 said: i've never ever seen a failed Lupo ECU. They are well designed... That's what the garage told me. 0 voltage output from the ECU. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 19, 2021 Report Share Posted July 19, 2021 Wipers and scuttle off. Battery off. See two power wires of decent thickness, maybe black/white or red? Nip into them and just put a 12v live to the battery. Fire the car up. Don't question the magic, just stick it on a switch to a 12v live in the cabin and fix the problem without stripping a lot out. Switch is because it will drain the battery. Relay easy enough but will require more skill/knowledge. 1 Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted August 2, 2021 Report Share Posted August 2, 2021 On 7/19/2021 at 12:22 PM, mk2 said: I disagree. More power than SDI yes. Quieter, no. More vibration. Same brakes. Less reliable engine but better gearbox than an SDI. @BlacknYellow i've never ever seen a failed Lupo ECU. They are well designed... @mk2I remember you said the same thing about my SDI ECU he he he. Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 2, 2021 Report Share Posted August 2, 2021 On 7/19/2021 at 9:46 PM, Rich said: Wipers and scuttle off. Battery off. See two power wires of decent thickness, maybe black/white or red? Nip into them and just put a 12v live to the battery. Fire the car up. Don't question the magic, just stick it on a switch to a 12v live in the cabin and fix the problem without stripping a lot out. Switch is because it will drain the battery. Relay easy enough but will require more skill/knowledge. It's just bypassing the existing Lupo relay... But, you're right. It's quicker to do that than change the dodgy relay. Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 2, 2021 Report Share Posted August 2, 2021 3 hours ago, Sarahs Lupo said: @mk2I remember you said the same thing about my SDI ECU he he he. Didn't you say that after the ECU had been changed it initially made no difference, which is why we were looking at temp sensors and stuff...? 1 Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted August 2, 2021 Author Report Share Posted August 2, 2021 Actually it was a damaged wire and nothing with sensors , ECU etc... All fixed and ready to be rolled out tomorrow Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 2, 2021 Report Share Posted August 2, 2021 Which wire? Please tell us... interesting. We can all learn from this. Pic? Quote Link to comment Share on other sites More sharing options...
BlacknYellow Posted August 2, 2021 Author Report Share Posted August 2, 2021 I will know tomorrow once I go pick it up. Once I know I will post it so we all know for future reference. 1 Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted August 3, 2021 Report Share Posted August 3, 2021 17 hours ago, mk2 said: Didn't you say that after the ECU had been changed it initially made no difference, which is why we were looking at temp sensors and stuff...? Bit of both. Yes and no. Quote Link to comment Share on other sites More sharing options...
