toblat Posted May 21, 2021 Report Share Posted May 21, 2021 (edited) Hi, I recently bought a 2003 Seat Arosa S 1.0 with 42k miles on it. Had an original timing belt so had that and the water pump swapped. I've recently noticed an intermittent ticking noise after the engine starts, which by the time i get to the destination seems to have stopped. Does this sound bad? I've done some research and have heard it could be tappets? Are these worth changing? Also i've been unable to fill up with petrol the whole way, the dash says its at half after i fill up, anyone had this problem? Edited May 21, 2021 by toblat more info Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 21, 2021 Report Share Posted May 21, 2021 (edited) Sounds like a normal 1L... Might be worth an oil and filter change if the tappets are sticking. Google how they work. A true wonder of engine technology Usually a hot engine flushes out any gummy residue, so check your temp gauge. Sticky thermostat...? And welcome to club lupo! Edited May 21, 2021 by mk2 Hello Quote Link to comment Share on other sites More sharing options...
toblat Posted May 22, 2021 Author Report Share Posted May 22, 2021 Hey, Thanks, that's good to hear! I think i will keep monitoring it as it's sometimes been louder than in that video :) Hmm, the temp gauge hasn't been getting too high. Cheers! I'm liking my arosa! Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 22, 2021 Report Share Posted May 22, 2021 When i get a new used car, i always change all the fluids (incl gearbox/brake/coolant), belts, filters and the thermostat. Worth it just for peace of mind so you know it's going to be reliable. An extra £50 is worth it to save a future breakdown taxi fee or tow home. Your model's weakness is plug leads, coil pack and engine sensors - all of which are relatively cheap and easy to replace and simply fail because of their age. You could swap them too if everything is original from new. Quote Link to comment Share on other sites More sharing options...
toblat Posted May 22, 2021 Author Report Share Posted May 22, 2021 Yeah that's a really good shout, I will defo be changing the fluids, and will do fan belt next MOT (did cambelt just recently). That's really good to know about the weak parts, thanks!! Quote Link to comment Share on other sites More sharing options...
toblat Posted July 4, 2021 Author Report Share Posted July 4, 2021 Hey @mk2 I just made another video as the noise seems to have gotten worse haha Seems that its only on cold starts, and it happens after the revs start slowing down (ie if i start the car later in the day it will sound fine). The noise seems to stop if i put it into reverse gear too. Reckon this is something bad or just tappets? Cheers, sorry to spam you again! (Noise starts at 0:48) Quote Link to comment Share on other sites More sharing options...
K3lv Posted November 25, 2021 Report Share Posted November 25, 2021 I know this is a very late reply but check your gear lever .....sometimes mine don't sit right and makes a knocking/rattling sound just a little tap forwards or backwards usually sorts it Quote Link to comment Share on other sites More sharing options...
