BioTriffid Posted April 21, 2021 Report Share Posted April 21, 2021 So I just changed the rear gearbox mount that bolts to the subframe and now the whole car is vibrating when accelerating or rolling along any help with this would be much appreciated guys thank you. Quote Link to comment Share on other sites More sharing options...
tigcraft Posted April 21, 2021 Report Share Posted April 21, 2021 I’ve known the rubber weight on the drive shaft cause that if it’s rotten. It might have been disturbed and it’s just as you described Quote Link to comment Share on other sites More sharing options...
BioTriffid Posted April 21, 2021 Author Report Share Posted April 21, 2021 Humm I'm sure mine is ok since they have been changed recently and the mount Is the only thing I've touched that can cause this can only try to fit the old one and see if it is because of a new part has been fitted Quote Link to comment Share on other sites More sharing options...
imaparana Posted April 21, 2021 Report Share Posted April 21, 2021 id get back under and have a look, might be something metal on metal or loose Quote Link to comment Share on other sites More sharing options...
BioTriffid Posted April 22, 2021 Author Report Share Posted April 22, 2021 It's weird how I've only touched that one thing and the whole car is vibrating more than a dildo lol Quote Link to comment Share on other sites More sharing options...
tigcraft Posted April 22, 2021 Report Share Posted April 22, 2021 Shove it on axle stands and run it in all gears then freewheel it to a holt and see what it does or not in this case 1 Quote Link to comment Share on other sites More sharing options...
