LUPO 1.7SDI COOLANT SENSOR
Sarahs Lupo
17 hours ago, mk2 said:
Yeah, it's the yellow bit in this pic (From EGR how-to), below the word "tied".
I'd check the output using VCDS before changing it. Might be ok.
Thanks!
I did check before and the coolant was the correct temp for the engine. But the dial on the dash is wrong/faulty.
It’s also using a little coolant every week so I’m hoping they are linked.
there are no leaks that I can see
