brake return spring
kurt7
Iv Just spent last 3 days doing pedal box . Test drive and brake sticks down when pressed also ignition coil light comes on when driving
need new clutch switch
Is there a correct position for the return spring I got a new brake pedal with new Spring does it clip into anything? Thanks for any ideas
Edited by kurt7
If it sticks, my guess is that something hasn't been put back right. The plunger should travel in and out quite easily, with the pedal connection point at the centre of the pivot. So when off, it should be slightly high, when pressed slightly low. Is the brake servo working ok?
yep it's like hit the brakes then I have to flick it back up with my foot , brakes working ok plastic cover was cracked over brake plunger, is there a way to make a rod to replace existing one so I don't have to remove and refit box  😟
Edited by kurt7
