Arc 1.6 l 16 v cam timing solenoid
Phillip kapp
Good day guys
I hope you can help i planted the 1.6 16v ARC into my polo vivo but have a problem with the vvt solenoid, meaning i lose oil pressure because of a busted solenoid.. being i imported the motor can't find a new solenoid. Can i use a different cam box on the 1.6 head? If so, which would you suggest?
Thanks from South Africa
Welcome to club lupo :)
try and fix it. Is it the seal? You could even rewind the solenoid coil with new wire....
Everything is fixable, especially if you have the skills to do engine part swaps.
