Rad fan not spinning
Tredest
So I was in traffic for about half an hour and my temperature gauge decided to shoot up!
Never noticed the fan not kicking in and when I pulled over to check the fan wasn’t turning while the engine was on. I’ve read this might be the temp gauge in the radiator but is there any way to check this? Which wires should I jump etc.
thanks
Edited by Tredest
Ok, so most likely fan motor, but also possibly fuse or thermostat switch (or controller module, depending on variant).
Try 12v straight to the motor first. If that's ok, then probably the switch (assuming the fuse is ok).
