kieran879 Posted May 31, 2020 Report Share Posted May 31, 2020 hey i was wondering if the vertical bolt on the wishbone is a nut and bolt or just bolted to the body. Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 31, 2020 Report Share Posted May 31, 2020 (edited) You mean subframe? It's a bolt screwed into a captive nut in the body. The bolt holding the bush in place is the same. You need to slide the bush forwards to get it out as there is a 'slot' that holds the central bit in place. Edited June 1, 2020 by mk2 Extra info Quote Link to comment Share on other sites More sharing options...
