Matt-Mk2 Posted April 26, 2020 Report Share Posted April 26, 2020 howdy folks The parking light on the drivers side will not go off, the indicator stalk is in the in the correct position, Any ideas ? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 26, 2020 Report Share Posted April 26, 2020 (edited) can you make the other side go on? does the drivers side switch off? do the indicators work as normal? do you have an after market remote central locking thing, which activates the indicator lights? Edited April 26, 2020 by mk2 Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted April 29, 2020 Author Report Share Posted April 29, 2020 On 4/26/2020 at 8:43 PM, mk2 said: can you make the other side go on? does the drivers side switch off? do the indicators work as normal? do you have an after market remote central locking thing, which activates the indicator lights? Drivers side goes off when changing over to the passangers side, but rear light on drivers side stays on indicators working fine, standard immo and RCL thought the initial problem was down to the led bulbs i put in the side lights, rear drivers parking light still on , took the bulb out, and changed it to see if it made a difference - no change, driving me potty lol Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 29, 2020 Report Share Posted April 29, 2020 Rear light "always" on, all the time? As in, you can't ever turn it off? Wierd. Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted April 30, 2020 Author Report Share Posted April 30, 2020 20 hours ago, mk2 said: Rear light "always" on, all the time? As in, you can't ever turn it off? Wierd. Yup only goes off when I disconnect battery, side light on drives side stays on aswel with it Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted May 5, 2020 Author Report Share Posted May 5, 2020 Narrowed the issue down to the light switch, ordered a new one to see if it makes a difference Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 5, 2020 Report Share Posted May 5, 2020 I'm curious to know if that fixes it. Never ever heard of any vdub (seat) ever doing that. Indicator related failures- loads. Never a light switch that keeps one side of the car's sidelights on. Plain wierd. Quote Link to comment Share on other sites More sharing options...
Rich Posted May 6, 2020 Report Share Posted May 6, 2020 Pull the fuse. Quote Link to comment Share on other sites More sharing options...
LR5V Posted May 6, 2020 Report Share Posted May 6, 2020 Could it be a faulty indicator, even when the stalk is centred, keeping the parking lights on? Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted May 7, 2020 Author Report Share Posted May 7, 2020 On 5/5/2020 at 11:18 PM, mk2 said: I'm curious to know if that fixes it. Never ever heard of any vdub (seat) ever doing that. Indicator related failures- loads. Never a light switch that keeps one side of the car's sidelights on. Plain wierd. New switch solved the problem , stripped down the old one and a few of the resistor literally fell off Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 7, 2020 Report Share Posted May 7, 2020 Can you post a pic of what you think failed... curious to know what caused it. Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted May 14, 2020 Author Report Share Posted May 14, 2020 On 5/7/2020 at 8:02 PM, mk2 said: Can you post a pic of what you think failed... curious to know what caused it. Also there was an open short on the switch itself Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 14, 2020 Report Share Posted May 14, 2020 Hmm. A 620 ohm resistor... I think that is there just to dimly power the led lamp inside the switch. Pleased you have sorted it anyway. If the same problem ever turns up ever again, we know how to deal with it now Quote Link to comment Share on other sites More sharing options...
Matt-Mk2 Posted May 15, 2020 Author Report Share Posted May 15, 2020 Mainly alot of swearing and scratches heads and many many searches for wiring diagrams Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 15, 2020 Report Share Posted May 15, 2020 LOL! Yeah. Been there done that... Especially engine looms. But is is surprising easy to pull out a vdub light switch when you know how (push the switch in and turn to the centre, then just pull it straight out). Handy if you need a low power 12V feed to power something like a dash cam, only when the ignition is on- and you can feed the wire straight up the A pillar with minimal effort from there Quote Link to comment Share on other sites More sharing options...
