miodek89 Posted April 2, 2020 Report Share Posted April 2, 2020 Hello. What is the way to unscrew the whip of the roof antenna? I unscrew up to a point and later does not want to leave .. Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 2, 2020 Report Share Posted April 2, 2020 The whip part has a male screw thread. It screws into the female thread on the roof base. Mine came off quite easily. It may be seized and require grips on the male thread. Good luck Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 2, 2020 Author Report Share Posted April 2, 2020 Tell me, does this antenna whip have such a "anti-theft" wheel at the end? Apparently some antenna whips had such a thing. You don't have to pull it harder or take it left and right when pulling? Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 2, 2020 Report Share Posted April 2, 2020 Not on mine. It was a simple screw out. I also just replaced one on my Mini Roadster and that too, was exactly the same. Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 2, 2020 Author Report Share Posted April 2, 2020 Unfortunately, nir does not want to leave so easily ☹️ For me, this is probably the tip of the antenna whip, so I do not want to go out so easily .. Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 2, 2020 Report Share Posted April 2, 2020 Both my antennae (Lupo and Mini) look like this: Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 2, 2020 Report Share Posted April 2, 2020 They came supplied with 2 different adapters. One 6mm to 6mm. One 6mm to 5mm Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 2, 2020 Author Report Share Posted April 2, 2020 (edited) Just like you showed i just want to buy just tell me how is my current antenna unscrewed? Edited April 2, 2020 by miodek89 Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 3, 2020 Report Share Posted April 3, 2020 If it’s like the ones I showed you, it will unscrew. i can only guess it may be rusted or cross threaded. Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Look 00:40 Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 3, 2020 Report Share Posted April 3, 2020 Mine was simple screw out/screw in. This video below appears to be yours too. Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 3, 2020 Author Report Share Posted April 3, 2020 I will try I'll let you know. And what whip do you recommend? Original or shorter? Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 3, 2020 Report Share Posted April 3, 2020 I bought original length aerials for both my cars. They were 40mm. The research I did suggested short stub aerials are not so effective as longer ones. Good luck Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 3, 2020 Author Report Share Posted April 3, 2020 So it's better to buy 40mm than a shorter antenna? And tell me how can I seal the antenna base? Some black silicone? Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 3, 2020 Report Share Posted April 3, 2020 Yes. Longer is better. i sealed by base with a new gasket like below. Fitted perfectly. https://www.amazon.co.uk/gp/product/B016QC6JZ0/ref=ppx_yo_dt_b_asin_title_o00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Thank you so much my friend. So now tell me how to replace such a gasket? Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 3, 2020 Report Share Posted April 3, 2020 It’s easy. Just place over the base and stretch it into place. No silicone is necessary. Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 3, 2020 Author Report Share Posted April 3, 2020 But I think I need to unscrew the antenna base? So I have to get to the nut in the headliner? Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 4, 2020 Report Share Posted April 4, 2020 Not necessary for the gasket. It stretches over the base Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 4, 2020 Author Report Share Posted April 4, 2020 Fact. But this gasket goes under the antenna and it is firmly screwed on, unless I speak wrong? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 4, 2020 Report Share Posted April 4, 2020 Some lupo antenna facts: There is a square silicone rubber seal moulded into the metal antenna bracket that bolts to the roof. The black rubber seal is basically just a trim. When you tighten up the nut on the inside, the force crushes the silicone seal against the roof sealing it perfectly. Problems only happen when salt spray starts to corrode the metal base and allows moisture to capillary around the seal. But by this time the rest of the car has probably already disolved away... Also, for best reception on FM or AM, you need a big antenna. It is known as "effective aperture". Imagine trying to catch fog passing the antenna "stick". But the size limit is set by the frequency band. Lower frequency, longer antenna... And, if you use a non OEM hifi unit, chances are that the antenna plug/socket is not powered. You need to supply a +ve feed to the circuit board in the antenna base. You can buy antenna power adapters to do that. The existing Lupo antenna base will not work with DAB or DAB+ radios. Ever. Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 4, 2020 Report Share Posted April 4, 2020 Thanks for that. I don’t know this stuff Quote Link to comment Share on other sites More sharing options...
miodek89 Posted April 4, 2020 Author Report Share Posted April 4, 2020 Thanks for the info. For me, this rubber gasket on the roof broke off in several places and I just want to do something to make it look aesthetically pleasing. Can some black silicone give? Unless you have other ideas? For me, the radio programs are from 90fm to 104 FM. This 40cm bat will be ok? The radio is not original. Pioneer is mounted Quote Link to comment Share on other sites More sharing options...
ArosaScott Posted April 4, 2020 Report Share Posted April 4, 2020 Ok, i can add to this also. Before i moved to a DAB unit i tried a shorter bee sting aerial and it didn't pick up the normal FM channels as good as the standard one. The aerial unscrews from the base till it wont unscrew no more and then holding the black base with one hand just the aerial a tug and it should release from the base. The normal standard aerial will NOT work with a 'splitter' for DAB, you'll need a powered aerial or one of the DAB windscreen mounted jobs. Quote Link to comment Share on other sites More sharing options...
Kevberlin Posted April 4, 2020 Report Share Posted April 4, 2020 The link I sent you will sort it. That is what happened to my rubber gasket Quote Link to comment Share on other sites More sharing options...
