_LM46 Posted February 12, 2020 Report Share Posted February 12, 2020 Hello, today my drivers side exterior door handle just stopped working, when u pull it it does nothing, the door will only open from the inside, it still locks and unlocks on the lock but the door handle on the outside won’t open the door, it pulls out like normal but doesn’t open, any suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
imaparana Posted February 12, 2020 Report Share Posted February 12, 2020 Ive had this recently, i reckon the small cable has become detached from the handle. There is a little grommet in the side of the door, take this off and there should be a torx head screw which holds in the lock, if you loosen this you should be able to pull the lock out and there you should be able to see that the cable isnt connected to the handle. Hopefully you can just pop it back in. Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 12, 2020 Report Share Posted February 12, 2020 I'll second that... Just be careful loosening off that T20 (I think) screw behind the grommet. You need to loosen it about 12 turns before the locking ring that holds the barrel in place releases. Keep trying every turn. Too many and the locking ring will drop down into the door. AND, once you have the barrel out, do not touch that bolt till the barrel is back in again. Quote Link to comment Share on other sites More sharing options...
