con9t2 Posted December 10, 2019 Report Share Posted December 10, 2019 Hi there, Over the past few months I've made quite a few posts about a re-occurring problem I was having, this issue has since been solved and embarrassed to say it was quite a simple fix - So I'm just posting this in case someone could use the tip. Check for leaks in the EVAP system, the hose that goes from the purge valve up to the throttle body should be good and tight. For months and months it would take a good 5-10 mins for my car to start and after a long process of elimination, all it turned out to be was this hose.. Quote Link to comment Share on other sites More sharing options...
Mooresy Posted December 10, 2019 Report Share Posted December 10, 2019 Interesting, I'm having lots of problems with mine at the moment, cant get it started at all after being laid-up for 2.5 years. I'll check this out. Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 10, 2019 Report Share Posted December 10, 2019 Another is the vac hose to the brakes leaking air. Took me ages to find that one. Quote Link to comment Share on other sites More sharing options...
con9t2 Posted December 12, 2019 Author Report Share Posted December 12, 2019 (edited) Spoke too soon, as usual! First day or two she started up first turn of the key no issues, since then it's gone back to several turns of the key, stuttering etc. I'm now also getting a P0321 code thrown up and from what I've read this may be the crankshaft sensor? Going to replace the purge valve just in case, in regards to the not starting issue. One thing I did notice is how my injectors were spraying fuel, (from left to right) 1 and 4 were noticeably lower pressure than 2 and 3 - Is this normal or would I need to replace the fuel rail also? I swapped over the injectors and they are all fine as it was still low pressure on 1 and 4, I'm thinking it's something to do with that, perhaps over fuelling in the rail? Thanks Edited December 12, 2019 by con9t2 Quote Link to comment Share on other sites More sharing options...
con9t2 Posted December 12, 2019 Author Report Share Posted December 12, 2019 On 12/10/2019 at 6:17 PM, Mooresy said: Interesting, I'm having lots of problems with mine at the moment, cant get it started at all after being laid-up for 2.5 years. I'll check this out. Definitely worth checking out, I replaced a few hoses that looked like they were standard issue....a 17 year old hose can't be good! Quote Link to comment Share on other sites More sharing options...
