weslangdon Posted November 25, 2019 Report Share Posted November 25, 2019 Problem is and was a soft pedal and excessive travel, changed slave and master cylinder with new ones but the problem persists. after a while the pedal firms up,😣😄 after a quarter of an hour or so, I'm mystified as the clutch isn't slipping or dragging and the gear change is as good as it was after the box was rebuilt 3 years ago. Any ideas out there? Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 25, 2019 Report Share Posted November 25, 2019 You need to reverse bleed is my guess. Pump fluid in from the slave end... I had a similar problem with another car a while back. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted November 25, 2019 Author Report Share Posted November 25, 2019 Thanks Quote Link to comment Share on other sites More sharing options...
LR5V Posted November 25, 2019 Report Share Posted November 25, 2019 Yes - reverse bleed is definitely the best i overcame my clutch bleeding saga using pump oil can - you want the pump lower than the slave, connect with hose to nipple, prime hose to remove as much air as possible -then you just pump keeping a close eye for bubbles at the reservoir. Before starting drain reservoir. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted November 26, 2019 Author Report Share Posted November 26, 2019 thanks Quote Link to comment Share on other sites More sharing options...
weslangdon Posted November 26, 2019 Author Report Share Posted November 26, 2019 At the moment the issue has gone, so am even more confused, the system did have a partial bleed when the slave cylinder was changed Quote Link to comment Share on other sites More sharing options...
LR5V Posted November 26, 2019 Report Share Posted November 26, 2019 Sounds like the offending bubble has worked it’s way out of the system Quote Link to comment Share on other sites More sharing options...
weslangdon Posted November 27, 2019 Author Report Share Posted November 27, 2019 I hope so but hope its not going to take fluid with it😃 Quote Link to comment Share on other sites More sharing options...
