cj1 Posted November 19, 2019 Report Share Posted November 19, 2019 (edited) Hi, I've recently acquired a Lupo GTI and in contrast to the rally car, this should provide a nice little project to restore a car that's in need of some good old TLC. 2004 6 Speed, Black 112k miles Sunroof So every panel is scratched and there are two large scuffs on the OSR and NSF. Interior is very clean, but the outside not so. I've made some minor cosmetic changes already, and discovering a few little issues with the car along the way. I shall use this first post as an active list to update with issues and modifications. I would like to keep the car as standard as possible along the way, but keeping an open mind. Modifications LED rear number plate lights LED Sidelights - match the factory Xenon's Red GTI Grille Piping Issues Car does not hold temperature or warm up, sits around 70 degrees - Now fixed with a new thermostat Steering doesnt feel right and occasional clunk feeling. Looks like split suspension arm bushes. Wipers split Engine cover split Heater controls are very, very hard to change from Window/Feet side to body side. Heater blower seems to make a squealing noise on speeds 1&2. Heavy kerbing to all four wheels Clutch Judder when moving at low speed, and a grinding noise in neutral. Suspect clutch release bearing. Ultimately the plan is to use this in place of the Arteon which I'm getting rid of in March. So got plenty of time to sort these issues out. I'll keep here updated, and pictures to follow Work Completed New Clutch & release bearing new suspension arms New ARB drop links New Ball Joints N/S Outer CV Boot replaced New track rod ends 4 wheel alignment New thermostat Replacement 6 speed gearbox cambelt & water pump changed Edited June 21, 2020 by cj1 1 Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted November 19, 2019 Report Share Posted November 19, 2019 I have a few issues too that sound the same. Be good to see you fix them welcome to the new GTi! Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 19, 2019 Author Report Share Posted November 19, 2019 11 minutes ago, Sarahs Lupo said: I have a few issues too that sound the same. Be good to see you fix them welcome to the new GTi! Do you have a build thread? Thanks! Have quite the collection of spare parts all sitting around from the rally car, so fortunately a lot of what I need I already have at home... Just finding the time to do it! 1 Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 19, 2019 Author Report Share Posted November 19, 2019 Plan on a cambelt/water pump change in the not too distant future either. Seems like it's just about due. 1 Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted November 19, 2019 Report Share Posted November 19, 2019 3 hours ago, cj1 said: Do you have a build thread? Thanks! Have quite the collection of spare parts all sitting around from the rally car, so fortunately a lot of what I need I already have at home... Just finding the time to do it! No build thread for me. I might see if I can start one. I'm on the same wave length as you. Mild restoration and small mods to make the car nicer to live with day to day Quote Link to comment Share on other sites More sharing options...
Blue Loop Posted November 19, 2019 Report Share Posted November 19, 2019 This thread is in need of photos ! Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 19, 2019 Report Share Posted November 19, 2019 May i ask what you paid for the slightly scruffy gti? Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 19, 2019 Author Report Share Posted November 19, 2019 (edited) Ok so here is a photo of the car and the headlight mod. I decided to just get cracking on with the suspension work as I saw no real reason to wait. The plan was to change suspension arms for now, and then when the ball joints and drop links arrive, do them separately. Anyway, the corrosion on the drop links had different ideas and the washer crumbled away. So it’s currently up on stands till I get it sorted. That being said, look at the state of the rear wishbone bush, I worry if this car had an MOT back in June with no advisories. ive discovered quite the rust tonight. The hubs, arms, drop links, tie rod ends are all flaking. So I’ll continue as planned, and change these this week. Next up will be acquiring a second set of hubs to clean up and paint, then they can be changed over in a few hours, rather than having to have the car off the road for even longer. (Albeit not much longer but rather not have to rush). And I’ll also ultimately be doing the same with the subframe that isn’t too bad but if I’m doing everything else, then why not I guess! Brake discs and pads aren’t TOO bad, but I’ll probably change them in the new year anyway. The callipers have been painted quite badly in silver, so they’re another on the list of things to clean and paint... Ultimately a lot of smaller jobs but nothing too bad yet! Edited June 21, 2020 by cj1 1 Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 19, 2019 Author Report Share Posted November 19, 2019 2 hours ago, mk2 said: May i ask what you paid for the slightly scruffy gti? I’d rather not say, it was originally posted on Facebook for £750 before the lady was accused of being a fraudster etc. Anyway fast forward a few offers off other people, the price did increase, not dramatically. Seemed to cause quite the stir on the Facebook group. But it was a decent price, well worth the money. 1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 20, 2019 Report Share Posted November 20, 2019 Bargain if at a grand! I really need to do FB...Damn! I pay more than that for a dented SDI with a mint interior. Interiors are the hardest part to restore. Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 20, 2019 Author Report Share Posted November 20, 2019 (edited) On 11/20/2019 at 7:38 AM, mk2 said: Bargain if at a grand! I really need to do FB...Damn! I pay more than that for a dented SDI with a mint interior. Interiors are the hardest part to restore. Yes it was definitely a bargain! Plus having so many brand new spares already made it a no brainer. Tonight I was pleasantly surprised. Looks like the wheel bearings have been done at some point recently as the driveshaft outer end popped out no problem, to reveal a nice shiny bearing! car currently on stands now with new wishbones and ARB drop links but all still apart as Awaiting ball joints and I decided it’s easier to wait than put it all back together now. Edited November 21, 2019 by cj1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 20, 2019 Report Share Posted November 20, 2019 When doing a restoration, I get the material for the driver's seat from germany or holland... It's the hardly sat-in passenger seat over there. If someone is breaking a lupo, it's a relatively quick job to peel off the cloth, away from the seat without harming it at all. Then cheap and easy to post (about 2.5 kg). You gain about 15 years of seat life that way The rubbery paint coated dash plastic parts are another story though. Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 21, 2019 Author Report Share Posted November 21, 2019 Tonight update - Impatience got the better of me and I've had both hubs off the car. Cleaned them up and got rid of the majority of the rust. Still waiting for the new ball joints to arrive before I can do much else. New suspension arms and ARB Drop links on both sides... Also got a new set of (used) hubs. Plan is to sand blast them, paint them up, then put completely fresh ones on the car. In no rush to do this as the current ones are functional! More to satisfy my desire to have this car rust free haha! I'll update with pictures once the ball joints arrive. Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 22, 2019 Author Report Share Posted November 22, 2019 (edited) Just waiting for the ball joints. New ARB Drop links, bottom arms are on waiting. Hopefully tomorrow! These bushes aren’t even seated in the arms; they were completely loose. Worrying they weren’t listed as an advisory as they’re just completely dangerous. Edited December 21, 2019 by cj1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 23, 2019 Report Share Posted November 23, 2019 MOT rules are- so long as there's no "excessive movement" or "metal to metal" contact, it will pass. But yeah, I've pulled out control arm bushes where the centres just drop out, but still pass. Unbelieveable. Apart from the bushes, those arms look like they're in great condition. I always cut mine out with a jigsaw... One cut in the ali outer rim and they just drop out. Quick. Then to the local gearbox place armed with either a tub of roses chockies or a 6 pack of ale (depending on time of year) and they let me use their press.... Quote Link to comment Share on other sites More sharing options...
LR5V Posted November 23, 2019 Report Share Posted November 23, 2019 I would have expected the tester to have at least covered their arse by putting them as an advisory. Invest in a cheap press - great for hubs and bushes, got one years ago, served me very well. Quote Link to comment Share on other sites More sharing options...
cj1 Posted December 2, 2019 Author Report Share Posted December 2, 2019 New suspension arms, ball joints, track rod ends, and drop links installed. Just had the geometry set up too. drives much better now the wheels are pointing in the same direction! Quote Link to comment Share on other sites More sharing options...
cj1 Posted December 21, 2019 Author Report Share Posted December 21, 2019 Clutch changed and yes, the noise and Judder seems to be due to the release bearing being pretty much none existent. It had seen better days! figured whilst the box was off to do the bearing it made sense to do the clutch (which was very worn anyway) . So the car is finally mechanically sound for now. At least the critical parts. Few issues still with interior functions... Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 10, 2020 Author Report Share Posted January 10, 2020 And the saga continues. im in need of a 6 speed GTI gearbox. Is anyone aware of any for sale or any GTIs being broke that may still have this available? Quote Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2020 Report Share Posted January 10, 2020 Refurb Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 10, 2020 Author Report Share Posted January 10, 2020 17 minutes ago, Rich said: Refurb Ideally would like to have one to go in whilst this one is refurbed.. save the car being off the road too long etc Quote Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2020 Report Share Posted January 11, 2020 Refurb is a lot quicker than you're thinking then. Plus you only do the work once this way. Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 11, 2020 Author Report Share Posted January 11, 2020 3 hours ago, Rich said: Refurb is a lot quicker than you're thinking then. Plus you only do the work once this way. Any recommendations on somewhere decent to do the refurb? Quote Link to comment Share on other sites More sharing options...
imaparana Posted January 11, 2020 Report Share Posted January 11, 2020 whats up with the box? Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 11, 2020 Report Share Posted January 11, 2020 Where are you? I've had 2 done so far by a very experienced guy I know... Takes about 2h of work max. £50. Split the case/pull the guts/remove bearing cases/power wash/press new bearings in/rebuild... done. Just make sure you get decent brand bearings like SKF, Timken etc. Ebay was the cheapest for a complete kit. Quote Link to comment Share on other sites More sharing options...
