Little tank
Breaking SDI
Was going to sell this but have decided to break. Thread was in for sale section but its probably better here.
Hello there, do you still have the passenger front wing, if so is it an LO41 colour black? Also what condition is it in, price, and would you post it? Sorry for the barrage of questions:)
       Many thanks   peter
Hi, yes i have the wing and the clutch pedal stop. The wing is abit rust. Ill get some pics so you can see for yourself.
what else have you got left??
thanks
how much for the clutch pedal stop??
       Many thanks   peter
Looked at wings today they are both rotten, not worth taking them off.
Looking for the tiny plastic pipe that runs front to rear between the EGR control unit on the bulkhead and the main servo pipe.  It's clipped to the radiator coolant pipe - and about 4mm in diameter and 13" long.
On 11/24/2019 at 5:43 PM, Little tank said:
Hi, have you go a pic of what it looks like, I'm having an mental blank.
Cheers Chris
Hi have you got a manual drivers side mirror, if you have, I'd like the inside cover that fits over the adjusting rod,  you lever it at the top then it should slide off the two grommets that hold it in position by pulling it down.
Yes, I have it.
7 hours ago, Sarahs Lupo said:
hey,
do you still have the glow plug wiring harness?
Also if you do what condition is it in?
thanks
I'm away at the mo, I'll dig it out at the weekend.
On 12/9/2019 at 12:45 PM, Little tank said:
Yes, I have it.
Yes, I have it.
I'll send you a pm
