Pedrodct Posted October 3, 2019 Report Share Posted October 3, 2019 Hi guys I'm new to this, I'm Pedro and I have a lupo gti with 130.000 miles, love that thing and I'm now restoring it. I'm also trying to fit it with r 32 mk4 brakes the bolt pattern fits the trouble is my mechanic tells me to get 17" wheels I don't want to do that, is it ok to grind some of the calipers metal away and use smaller disk with 4x100 pdc, also I've upgraded to 16" bbs rx 2 hope this makes sense Quote Link to comment Share on other sites More sharing options...
Rich Posted October 3, 2019 Report Share Posted October 3, 2019 Even 312 won't fit with 16" Rx unless you grind the calipers MK3 288 brakes with calibra discs in four stud. 1 Quote Link to comment Share on other sites More sharing options...
LR5V Posted October 3, 2019 Report Share Posted October 3, 2019 BBS RX2's are nice wheels, I used to run them on a Mk3 - but you need to be aware that they are one of the worst OEM wheels for space inside for brakes. On my Mk3 the caliper was only a few mm of the inside of the spokes. I can also report that the RX2's are heavy, a nightmare to clean and it seems their second function in life is to corrode. If you do go with the R32 calipers, ignoring wheel space, you will need to make custom carriers for the calipers to fit on. I would stick with the common upgrade retaining the existing calipers and using them with 280 discs and carriers. 1 Quote Link to comment Share on other sites More sharing options...
Pedrodct Posted October 6, 2019 Author Report Share Posted October 6, 2019 I've had the bbs rx refurbished they are looking good, maybe I will go with the corrado brake system should be easier to install thanks alot anyway guys Quote Link to comment Share on other sites More sharing options...
Pedrodct Posted October 6, 2019 Author Report Share Posted October 6, 2019 On 10/3/2019 at 11:45 AM, Rich said: Even 312 won't fit with 16" Rx unless you grind the calipers MK3 288 brakes with calibra discs in four stud. Thank you I forgot to mention that I have 15mm spacers Quote Link to comment Share on other sites More sharing options...
Rich Posted October 6, 2019 Report Share Posted October 6, 2019 They will clear the 288. Quote Link to comment Share on other sites More sharing options...
