Murtada Al Shawi Posted September 10, 2019 Report Share Posted September 10, 2019 Hello everyone 🙂 I have bought a used Lupo 1.4 FSI benzin for my wife here in Sweden and its a very nice and small car. The problem is that it jutters both when using automatic and semi automatic gear. This problem increases after 4-7 hours of driving at mixed speed (highway and city). Suddenly after driving for 40 km of distance at a speed of 100-120 km/h the car can suddenly have difficulty in continouing the speed, drops in speed slowly and the engine temperature drops from 90 to 70 and lower. I have changed the plugs and now I changed the oil and the oilfilterand added fuel cleaner. The car became a little bit better but the problem persists. The error code I get is P1072 ( otherwise no other codes.  What do you think the problem is? And how to solve it? Quote Link to comment Share on other sites More sharing options...
Rich Posted September 10, 2019 Report Share Posted September 10, 2019 Check the coilpack for green corrosion. Also debate a green temp sender and a thermostat. Quote Link to comment Share on other sites More sharing options...
mk2 Posted September 10, 2019 Report Share Posted September 10, 2019 If the temperature gauge shows the temperature dropping, but you drive normally, @Rich is right. It is probably the temperature sensor. Loss in power is because it is running on a cold program. Plugs were probably dark or nearly black when you changed them... welcome to club lupo!  Quote Link to comment Share on other sites More sharing options...
