Stua9
What bit at the back does this mean
It was part of an mot fail i haven't had a look yet
"Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength"
I looked inside before taking just doing my nosey and cleaning ect and the shocks top mount looked spot on, no rust nothing but that's inside. I take it it's maybe right underneath the top mount ie at or near the axle/beam?
Axle beam.
Should be obvious.
Is it a new axle then
Probably will be once I look as I said I haven't yet... can they be welded or no.
Edited by Stua9
I might scrap it as there's other stuff too... so much for getting something to be cheap to run.... I'll keep the bm.
It's not going to be an axle and if you would scrap a car for a bit of rust, well, all the best with the bm
Have a nice day
I had to do a bit of welding on one of my SDIs just the other day.... Ok, so more than a bit, but hey, they are 20 year old cars now.
Have a nice day
 What would you know without seeing it!!
I sure will ;  )
You're right I'm going to take it to the guy I use thing is he doesn't do welding now but will get him to see where the tester is on about. I had a look yesterday, yes there's a lot a of rust round the whole area but I could see that "Is structurally weakened". Failing that I'll go and ask the tester exactly where he means.
Edited by Stua9
It should have a chalk outline.
That's a fair bit of work...it starts at the top of the wheel arch and works it's way down the seam. Once fixed, pump loads of waxoyl in there.
No it's the sill at the back ns but the way it was worded in the fail sheet confused me
