Stua9 Posted September 6, 2019 Report Share Posted September 6, 2019 I've got an 03 Arosa and yes the bloody boot only opens from inside but.. I had the lock ect off, it works fine locking it from the fob but won't unlock, now what I don't get. Everything's free and not stuck ect so why won't the long rod from the lock going to the actuator move down itself, I need to pull it. Like I say, the lock and actuator works fine but the this bloody rod won't move down on it's own.. Quote Link to comment Share on other sites More sharing options...
Sausage Posted September 6, 2019 Report Share Posted September 6, 2019 Broken spring, weak actuator? Quote Link to comment Share on other sites More sharing options...
Stua9 Posted September 6, 2019 Author Report Share Posted September 6, 2019 Spring (in the lock) is fine but how would I know if it's weak, actuator's fine to but greased it for good measure. Quote Link to comment Share on other sites More sharing options...
mk2 Posted September 6, 2019 Report Share Posted September 6, 2019 (edited) The push-pull force is the same either way from the actuator. So if you do it by hand, the lock/unlock force to make the mech work should 'feel' the same. If not, something has broken or dropped off... Or it could be a dodgy electrical relay contact in the CCV module? Just a guess though. Edited September 6, 2019 by mk2 Quote Link to comment Share on other sites More sharing options...
weslangdon Posted September 6, 2019 Report Share Posted September 6, 2019 Have you sprayed wd40 or similar onto your key prior to inserting it, accepted its likely something more complex but I've had that problem with an Arosa and it just needed extra lubrication Quote Link to comment Share on other sites More sharing options...
