mk2 Posted August 13, 2019 Report Share Posted August 13, 2019 SDI and tuning in the same breath?! If that's even a 'thing'... Just thought I'd update all you non turbo, diesel tuning people out there. Over the last few months I've been running DLSA150P544 injector nozzles. Same economy on a run, but accelaration torque is way better. Who says you need a turbo? All good, and car 'almost' keeps up with a stock lupo GTi! No access to rolling road at the mo, so no idea what power gain if any. Definitely more torque though. I also adjusted the injection pump quantity adjuster to make it idle at 0.2mg when warm. So a bit more fuelling top end, like 5mg. In theory about 15-20% more fuel. More fuel = more power in a diesel. But. Yesterday my car failed its MOT on emissions. D'oh. Smoke reading when blipped to between 6-7.5. Limit is 0.7 on the plate. Oh. Took it on a quick 20 mile blast to clean anything out, along with some purge in the tank (i don't think the stuff works). Retest. No change. Back to the workshop and had a dig around for some original P745 injectors (0.190mm holes). Chucked em in. Back to tester who was now laughing... Scraped through with an average (after a few tries) of 0.66 smoke. Pass. Moral of the story- you can have more grunt from an SDI, but it's not gonna be legal... 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted August 13, 2019 Report Share Posted August 13, 2019 Dodgy mot! 1 Quote Link to comment Share on other sites More sharing options...
Skezza Posted August 13, 2019 Report Share Posted August 13, 2019 Purge in the tank does nothing really. We both know that. Did you not do the full setup like I've said before. That includes running your own independent fuel source from a pop bottle or something? Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 13, 2019 Author Report Share Posted August 13, 2019 Yeah, probably true, but I can't prove it. The good ol' pepsi bottle has been useful for experiments, but I've never conclusively found it to make any difference if running almost neat 'purge fluid' or diluted with a few litres in the main tank. I'll have a chat with one of the guys I know who does the development for BP's fuel additive division half a mile from here. He's told me some interesting stories about fuel additives. Apparently up till recently, Australia was one of the last countries in the world to run 100% pure 'distillate', without any detergents or anything. They know their stuff. Naturally, the BP premium diesel fuel is the world's best... Ever since, I've been using that in the tank (almost empty with just a few litres of the stupidly expensive (like 25p a litre more than regular) diesel just before MOT day. Up till now always good. Apart from I'd forgotten that I'd swapped the injectors over about 10 months ago. My MOT guy is absolutely straight down the line. My cars are all stock so I like it when he's very critical, because it helps me identify things I hadn't spotted (not often...). The smoke test is interesting because if you test just after a run- like seconds, it's always good. If the car is allowed to idle for 30+ mins (while examined) then tested, the numbers are obviously going to be higher. So I guess, the true reading happens after any soot build up has been blown out of the silencers. I wish I had a smoke tester that I could rig up to a car while driving it to see the actual readings under steady load. My first MOT fail for a very long while. I had to take it in... Woah! Quote Link to comment Share on other sites More sharing options...
yeha Posted August 15, 2019 Report Share Posted August 15, 2019 Rolling coal... Quote Link to comment Share on other sites More sharing options...
Stephenmacleod Posted October 21, 2019 Report Share Posted October 21, 2019 Any other mods done and mapping? Or just a straight injector nozzle change? Quote Link to comment Share on other sites More sharing options...
Stephenmacleod Posted October 21, 2019 Report Share Posted October 21, 2019 On 8/13/2019 at 10:23 AM, mk2 said: SDI and tuning in the same breath?! If that's even a 'thing'... Just thought I'd update all you non turbo, diesel tuning people out there. Over the last few months I've been running DLSA150P544 injector nozzles. Same economy on a run, but accelaration torque is way better. Who says you need a turbo? All good, and car 'almost' keeps up with a stock lupo GTi! No access to rolling road at the mo, so no idea what power gain if any. Definitely more torque though. I also adjusted the injection pump quantity adjuster to make it idle at 0.2mg when warm. So a bit more fuelling top end, like 5mg. In theory about 15-20% more fuel. More fuel = more power in a diesel. But. Yesterday my car failed its MOT on emissions. D'oh. Smoke reading when blipped to between 6-7.5. Limit is 0.7 on the plate. Oh. Took it on a quick 20 mile blast to clean anything out, along with some purge in the tank (i don't think the stuff works). Retest. No change. Back to the workshop and had a dig around for some original P745 injectors (0.190mm holes). Chucked em in. Back to tester who was now laughing... Scraped through with an average (after a few tries) of 0.66 smoke. Pass. Moral of the story- you can have more grunt from an SDI, but it's not gonna be legal... and are these nozzles a standard from another vehicle or custom? thanks Quote Link to comment Share on other sites More sharing options...
Sarahs Lupo Posted October 21, 2019 Report Share Posted October 21, 2019 this is great mk2 , you really know your stuff with these cars Quote Link to comment Share on other sites More sharing options...
mk2 Posted October 21, 2019 Author Report Share Posted October 21, 2019 13 hours ago, Stephenmacleod said: and are these nozzles a standard from another vehicle or custom? thanks Standard nozzles from a 1.9 TDI. You need the same dispersion pattern or spray, so the only thing you can change (realistically) is the size of the injector holes. The rest of the diesel system is identical. Mapping is different though as the 1.7 pumps less air than a 1.9 TDI. The trouble is that the amount of air needed to burn any extra fuel isn't really available, so you get a choking mix, giving you black smoke. And the speed of the burn (cetane rating) is fixed, so if you try and do what people do with petrol engines by pushing up the revs a bit to eek out more power, also won't work, because you run out of burn time. By the time the piston has made it to half way, you want all of the mix to have caught fire. Can't happen if the piston is moving faster. Think bicycle pedal- max push (gas pressure) when the crank is horizontal. (Direct injection petrol engines also have the same limitations- insufficient injection time at high RPMs) But one thing that really does make a big difference to an SDI is the gas flowing of the inlet manifold. Block off the 4 EGR injection ducts with some ali rod then die grind the whole thing smooth to keep the air laminar. I've posted "how to" pics a few years ago. The car now cruises a lot easier. People who have driven my SDIs after driving their stock versions always ask what on earth have I done to the engine. Gas flowing. That's all. Was fun with the bigger injectors in though. Quote Link to comment Share on other sites More sharing options...
Stephenmacleod Posted October 21, 2019 Report Share Posted October 21, 2019 9 minutes ago, mk2 said: Standard nozzles from a 1.9 TDI. You need the same dispersion pattern or spray, so the only thing you can change (realistically) is the size of the injector holes. The rest of the diesel system is identical. Mapping is different though as the 1.7 pumps less air than a 1.9 TDI. The trouble is that the amount of air needed to burn any extra fuel isn't really available, so you get a choking mix, giving you black smoke. And the speed of the burn (cetane rating) is fixed, so if you try and do what people do with petrol engines by pushing up the revs a bit to eek out more power, also won't work, because you run out of burn time. By the time the piston has made it to half way, you want all of the mix to have caught fire. Can't happen if the piston is moving faster. Think bicycle pedal- max push (gas pressure) when the crank is horizontal. (Direct injection petrol engines also have the same limitations- insufficient injection time at high RPMs) But one thing that really does make a big difference to an SDI is the gas flowing of the inlet manifold. Block off the 4 EGR injection ducts with some ali rod then die grind the whole thing smooth to keep the air laminar. I've posted "how to" pics a few years ago. The car now cruises a lot easier. People who have driven my SDIs after driving their stock versions always ask what on earth have I done to the engine. Gas flowing. That's all. Was fun with the bigger injectors in though. Pd130 i assume? Cheers for that, may have to have a look up on your old post with pics. Got a link by any chance? Bathroom reading haha. Quote Link to comment Share on other sites More sharing options...
