Mr
Lupo gti 20v t conversion fuel pump issue
Having fuel pump issues with the conversion start with a breakdown with where I am
Both looms where sent off and ecu for immobiliser delete that was a while ago as the project was not started for a while
Loom fitted ecu fitted
Engine all fitted and connected
Pipe work fitted but no water in pipes
This is where we are stuck then we put the earth back on the the brake lights stay on and the pump will only work when the door is open it pre primes
When you turn the ignition on no pump
Car will just turn over but want fire no power to the following
To coil packs
Injectors
Throttle body
And pump to the ignition
Cannot get into the ecu via the odb port or the airbag system only the abs
Changed and checked every relay
We where thinking ECU issue any idea's as we are just going round in circles
I'd say wiring issues.
Who did it?
Anybody got a diagram for the ecu plug?
20v ECU? - looms differ between engines, you need to give us the engine code
My Mk4 Golf AUM has an odd relay in the engine bay that would play up from time to time, wasn't aware of it till someone told me about it.
It's the bam engine and loom we are running I thought I added that above 😂
Wiring for sure. You could probe all the ecu pins and see which one goes high/low while cranking. Diagram much easier. Sounds like more than one relay or control wire (to relay).
Don't know if my upload is going to work not done it before but this should help too, although don't take autodata as gospel :lol:
Bam 1
Bam 2
Bam 3
Bam 4
Bam 5
Bam 6
Bam 7
Bam 8
The pictures are huge so you'll have to do some zooming and scrolling and the last 3 your likely not going to need, I didn't :D
Been away back to the car now found that the 62 pin was not fully pushed in so now have power and can start the car but no throttle response
Checked the voltage on the throttle body only 5v going to it anybody got any ideas looks like its loom related but any help would be great thanks
Yeah. TPS output should vary between about 0.5-4.5VDC. One side +5V the other 0V, but not usually the same potential as earth (helps reduce interference).
Glad you have progressed past the fuel pump problem... but sorry to hear its still mucking you about - I assume you have checked all the other pins are pressed fully home?
As Mk2 says 5v is normal. Assuming you have kept the BAM as DBW? I would look on vagcom to see if your accelerator pedal is sending signal to the throttle body, at least do a throttle alignment whilst you are there.  If that's not possible continuity check the cables to the pedal and all 6 throttle body cables.
It's turning into a ball ache now so far it looks like the throttle wires are wrong there not matching the throttle pedal side looks like 2 wires are wrong so far just going through the checks on the diagrams we have printed off
Trying to find the lupo gti ecu wiring diagram  or throttle pedal diagram but can't find that one any where, need to see what the wires are on the throttle pedal side just to confirm it's wrong
This is from ARC/AVY polo wiring diagram
G79 accelerator position sensor
G185 accelerator position sensor 2
Edited by LR5V
The way it works, is one of the outputs (potentiometer wipers) increases in voltage while the other decreases. Done like that to ensure no accidental accelaration. So you'll find that when you measure it, one is at something like 4.5V and the other is around 0.5V. The non moving parts are at 5 and 0 (and 0 and 5).
Got it going now thanks for all the help the 6 wires was wired wrong managed to sort it out as we only do it on a Thursday and Saturday hence why not on here often due to work to reply had a issue with the heaters as well just rebuild and see what else we hit then will add some pictures on here Friday to show how the build is going
Back to it again and yet another loom issue, this time the speedo the rev counter works no speedo!!
Looks like everything out job to correct may as well have just done the loom to start
Check the power supply to the speedo sensor. It usually has 5V and 0 and a 5v output square wave signal. You should be able to see the same signal in the dash. If you turn the sensor spindle in your fingers and connect up a voltmeter, you should see that output signal. :)
