Drivers electric window kaput...
oldstout
I need to investigate a non working leccy window in one of my SDIs. It suddenly started working a few months ago on a day when it was below freezing the whole day. Then ceased again once it warmed up a bit. I have a hunch that the anti fingertrapping 'system' is based on an over-current sensor that measures the excess current before the top stop is reached. And if it is, chances are that by changing a 5p resistor or something could set the current to a different level (to compensate for friction and wear).
1 hour ago, Sausage said:
what are your windows doing / not doing?
Switches are weak, regulator bits are weak.
You can bypass switch as here:
Press the switch, nothing happens, no sound, no window down. He's gonna struggle at McDonald's drive thru...
You get any further with your hypothesis? 🤔
