Nazzywazzy Posted June 3, 2019 Report Share Posted June 3, 2019 Hey everyone, My car struggles to start in hot weather so I've scanned it using the VCDS Lite software and it has come up with the following codes: VCDS-Lite Version: Release 1.2 Monday, 03 June 2019, 17:53:18. Chassis Type: 6X - VW Lupo Scan: 01,02,03,08,15,17,19,25,35,37,44,45,55,56 ------------------------------------------------------------------------------- Address 01: Engine Labels: 036-906-014-AHW.LBL Controller: 036 906 014 BLw Component: MARELLI 4CV 2802 Coding: 00003 Shop #: WSC 01236 VCID: D2D7794B0DF7 5 Faults Found: 01249 - Fuel Injector for Cylinder 1 (N30) 29-10 - Short to Ground - Intermittent 01250 - Shareware Version. To Decode all DTCs 29-10 - Please Register/Activate - Intermittent 01251 - Shareware Version. To Decode all DTCs 29-10 - Please Register/Activate - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 29-10 - Short to Ground - Intermittent 01312 - Shareware Version. To Decode all DTCs 37-10 - Please Register/Activate - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Controller: 001 927 749 G Component: AG4 Getriebe 001 2022 VCID: 1E4F5D7B89AF No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL Controller: 6Q0 909 601 Component: 02 AIRBAG VW5 0003 Coding: 12338 Shop #: WSC 01236 VCID: F093D3C3A3BB 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent Any ideas what they mean? Thank you Quote Link to comment Share on other sites More sharing options...
Sausage Posted June 3, 2019 Report Share Posted June 3, 2019 The first ones are injectors, the fact all 4 are affected says electrical fault like wiring, control module etc. Check the fuses. http://wiki.ross-tech.com/wiki/index.php/17648/P1240 The 01312 one looks like data bus: http://wiki.ross-tech.com/wiki/index.php/01312 Last one is airbag. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 3, 2019 Report Share Posted June 3, 2019 Could be a main power relay. They generate the same problems and fault codes. Yeah, could be a fuse. Fault to ground could mean that the injectors are actually ok, as is the wiring, but the 12v supply isn't there. So the ECU thinks that the supply has been shorted out (to ground). It should say, short to ground or faulty supply... Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 3, 2019 Report Share Posted June 3, 2019 Like most fault codes, always suggest clearing them first, see what returns. Your airbag fault for example is basically a false positive. Quote Link to comment Share on other sites More sharing options...
Nazzywazzy Posted June 6, 2019 Author Report Share Posted June 6, 2019 Thanks guys, great help. I am taking my car to a mechanic on Monday, fingers crossed I can get this problem sorted! Quote Link to comment Share on other sites More sharing options...
