James_VW Posted June 2, 2019 Report Share Posted June 2, 2019 Where is the gearbox code located on a GTi 6 speed gearbox? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted June 3, 2019 Report Share Posted June 3, 2019 They only used these codes, FUT, GPF, GSN, GVX, and HBK. They have all superseded to part number 02U 300 050 CX. It should be stamped near the selector tower on the top of the box. Quote Link to comment Share on other sites More sharing options...
LR5V Posted June 3, 2019 Report Share Posted June 3, 2019 It is pretty well hidden, the PN is a read herring, code is just above the clutch slave cylinder: The letters are machine made, punched pin marks - difficult to see - I used a black marker to fill the recesses to highlight the letters. Quote Link to comment Share on other sites More sharing options...
LR5V Posted June 3, 2019 Report Share Posted June 3, 2019 You can just see GSN in this picture: Quote Link to comment Share on other sites More sharing options...
James_VW Posted June 3, 2019 Author Report Share Posted June 3, 2019 I have checked the top and I have: WWO O2T301103T GD-TL 023 I was worried the WWO was the gearbox code but I have cross referenced with another GTI 6 speed that also has the same numbers. I will check that spot and see if I can spot it! Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted June 4, 2019 Report Share Posted June 4, 2019 Part number 03L 301 103 T is fitted to a GVX gearbox code, it is the part number for the end case Quote Link to comment Share on other sites More sharing options...
James_VW Posted June 7, 2019 Author Report Share Posted June 7, 2019 Thanks for your help. Discovered to be GVX. Quote Link to comment Share on other sites More sharing options...
