imaparana Posted May 27, 2019 Report Share Posted May 27, 2019 (edited) Hi all, ive noticed this evening in my lupo gti rally car, with abs fuse pulled, the rear brakes are wanting to lock under heavy braking. Does anyone know if the abs unit does the brake proportioning ? or if there is a separate system that does it? Cheers! Edited May 27, 2019 by imaparana Quote Link to comment Share on other sites More sharing options...
yeha Posted May 29, 2019 Report Share Posted May 29, 2019 The ABS system does it all. The proportioning valves are on the non-abs cars. You need fit a bias bar or pressure limiting valve or both. Some good info on the pros/cons of each on British Rally. I have a mk1 Golf with the same brakes and it will slide very nicely with a good stomp on the pedal.. Quote Link to comment Share on other sites More sharing options...
imaparana Posted May 30, 2019 Author Report Share Posted May 30, 2019 19 hours ago, yeha said: The ABS system does it all. The proportioning valves are on the non-abs cars. You need fit a bias bar or pressure limiting valve or both. Some good info on the pros/cons of each on British Rally. I have a mk1 Golf with the same brakes and it will slide very nicely with a good stomp on the pedal.. Cheers, that explains a lot have ordered a Bias valve so hopefully thatll sort it Quote Link to comment Share on other sites More sharing options...
cj1 Posted May 30, 2019 Report Share Posted May 30, 2019 4 hours ago, imaparana said: Cheers, that explains a lot have ordered a Bias valve so hopefully thatll sort it Back end still locks up on mine with the bias valve wound all the way off. You get used to it. Quote Link to comment Share on other sites More sharing options...
