jackgraham
Oil in coolant, help!
Hi everyone, apologies if this is in the wrong place...
I've a w reg 1.0l which I serviced the other day. As the coolant light has been coming on intermittently I decided it would be a good idea to drain and refill.
I removed the bottom hose from the radiator and there was a significant amount of oil in the coolant, since refilling it now appears that there's still a significant amount left in the system as its still brown and sludgy in the resrvoir
As far as I know it's not the head gasket, still runs perfect in start stop traffic and isn't overheating. The engine oil wasn't contaminated either when I drained it. Any idea what could be causing this? I've seen some suggest it could be a faulty radiator, Or just a case of properly flushing the system?
Dont think there's an oil cooler on these is there the filter goes straight in the block?
HG can fail in several ways so oil in water doesnt need to be misfiring. Look around edge of HG for oil or water weeping etc. or could be a crack somewhere block or head allowing them to mix.
Update on this...
Coolant has now turned into a very sludgy brown mixture so will need flushing a bit more thoroughly this time, I'm thinking something like holts /similar to help it along
Still no overheating which is a bonus! Might try steel seal and see if it lives up to the hype
Headgasket, crack or oil cooler leak for sure... It'll be just a question of time before it finally goes.
11 hours ago, jackgraham said:
Update on this...
It does work, it's just a nasty way of fixing it. Do it properly though and it does work.
If oil is getting in the water and not water getting in the oil then the oil is under higher pressure, I doubt any treatment you put in the water will work in this case, but if you can find it cheap enough then a few quid is worth the gamble.
There is oil seal in the head gasket around high pressure feed, that area would be prime suspect. Worth flushing system out and seeing what happens then though, maybe some doofus has put oil in the water by mistake (it happens).
Dishwasher tablet in coolant tank will clean everything nicely. :)
Equally, I watched a severely distracted mechanic pour a significant amount of coolant straight into an engine. I try in vain to shout round the door (was watching him through the glass) but it was too late and he then realised what an absolute balls up had occurred. Wonder how they sorted that mess out? It wasn't my car luckily. You'd think however, drain the coolant out the engine obviously, fill up with fresh oil, run at idle up to temperature, two or three revs to get the pressure up(?),  drain again, then completely fresh oil? Would that actually be enough.... My concern would be that good old science never lies and a simple rule of physics is that oil and water do not mix, they separate.......... so how do you know for sure that adding fresh oil is even going to guarantee it extracts all the coolant left in the block? A sticky situation, undoubtedly. Glad I wasn't the young man who made that mistake.
Does that actually work? I don't mind the idea of coolant flush but a dishwasher tablet surely has loads of detergent and stuff that won't play nicely?
I once left off a sump plug while filling with fresh oil... I think that's about as dumb a mistake I've ever made.
Yeah dishwasher tablets work a treak. Add two to a big system (10L). Designed to not attack rubber or cause corrosion to any metal and even de-limescales too. Any oils or contaminanents go into suspension then get dumped when you drain it. Just rinse through with fresh water at least three times before filling with antifreeze again. The anti freeze last years that way and stays lovely and clear. No pinky cloudiness.
I'll remember that. Very useful
I know this.
Standard practice
Update numero 2...
I'm concluding it's the HG as the exhaust is pretty white too, I'd not noticed this before.
After consulting many YouTube videos I did several normal flushes (drain, fill with water, run up to temp, cool, drain again and repeat) and then did a flush with laundry detergent. The laundry detergent actually worked wonders and pulled several shades of s**t out! As per above comments its designed to work with rubber hoses, aluminium and other metals so can't be too harmful, and wasn't in the system long enough to do any damage.
Just done another flush with holts flushing solution which has brought out lots of other bits and pieces of corrosion mostly, gonna try the steel seal tomorrow and keep everything crossed.
I'd have faith in the steel seal.
But I would also take the spark plug out of each cylinder and run it on three for thirty minutes each, unplug the injector too.
You should also devise a way to increase the water pressure.
I don't think it'll work, but hey worth a try.
Pull the head off. By the end of Sunday you could have it runnig again :)
Leave the oil cap off?
Pulling the head off is a bit too advanced for me and my toolbox 😂 finished my final flushes today (4 times, just to be sure) and haven't seen any more oil come out which is a relief. I'm gonna go with the steel seal still because I'm 90% the head gasket is on its way out, and I'd rather give a £40 bottle a go instead of waiting for it to go boom in a week/months time. Here's hoping the green machine lives on!
A tenner might be worth the gamble, I dont think £40 is.
You may as well use it as is while monitoring its oil and water quality and levels.
Hey and you have the matching bucket. Gotta keep the car running now!
£27 in my local motor factors.
I like that.
I'll take a £40 punt over buying another lupo!
Just had a pretty hard drive out on a country road for 10 miles with steel seal in and seems to have done the job, exhaust isn't blowing white ish anymore and the coolant looks the same as it did out of the bottle. Held temperature pretty standard the whole drive too which was a relief
Time will tell whether its properly done the job but early results seem positive, thanks for all the contributions!
